A big firmware update for the Arturia PolyBrute
Arturia have released a very nice update for the PolyBrute :thumbup::clap:
Informational video: https://www.youtube.com/watch?v=nyUd2IzTNOk
The update can be obtained from the '_PolyBrute' section in https://www.arturia.com/support/downloads&manuals
Arturia wrote:New features
  • Added Distortions FX feature accessible by clicking on the "Type" button from the modulation section until the 3 LEDs are lit
  • Added "Mod FX Send Routing" settings accessible by holding "Settings" and click FX button. This allows you to choose your Modulation effect routing in the effect signal chain
  • Added options to fine tune the VCO1 accessible by holding "Settings" and turning the VCO1 "Tune" knob
  • Added a new "Stereo Layer" Mode accessible by holding "Settings" and clicking on "Timbrality" when in Layer mode. Uses two voices per notes and panned them on left and right channel
  • Added a keyboard-transposition feature accessible by holding "Settings" and clicking the "Octave Shift Left/Right arrow"
  • It is now possible to choose how many detune amount you set for each voice when in "Unison" mode. The feature is accessible in the "Setting / Synth Voice / Voicing / Unison Detune" menu
  • Added Duophonic PitchBend settings accessible in the "Settings/Expression Control/Duo Controls" menu
  • Added an "Envelope Reset" feature accessible by holding "Settings" and moving any "Sustain Envelope"
  • Added "Sync In/Output" options to filter incoming or outputted clocks accessible in "Settings/Sync/Source" menu
  • Added an option to not send Midi Clock Message accessible in "Settings/Sync/Transport Send" menu
  • Added Modulation Envelope Amplitude as a matrix destination
  • Added an option to send Program Changes messages accessible in the "Settings/MIDI/Program Change" menu
  • Allow users to adjust the LEDs intensity. The option is accessible into the "Settings/MISC/LED Brigthness" menu
  • "Glide" is now working with the arpeggiator
  • Added a Modulation Envelope Delay visualizer
  • Last preset saved is now recall when rebooting the unit
  • Using the "Panic" feature now also kill the voices
  • "Allocation" menu has been renamed "Voices"
  • Setting “Analog Accuracy” moved to “Settings / Synth Voice / Voicing” menu
  • "Hold" button is now activable from the unit in Local Control OFF
  • Lower range of Delay and Reverb level has been adjusted to get more precision in low values (previous presets won’t be affected)
  • Snapshot time display now represents the delta between the current time and the saved snapshot
  • Now even old presets use the “VCA Linear curve” : the menu is still accessible by holding "Settings" and moving "Decay Env" if you want to compare the new behaviour vs the old one
  • Ribbon and Morphee modes are now displayed on their respective screens
  • Added confirmation pop-up for the "Morph" utilities function
  • Added a "Voices Mod Source" setting accessible in "Settings / Synth Voice / LFO". It allows to defines the kind of signal that is used for the Voices modulation lane
  • Split point is now displayed when holding "Timbrality"
  • Added LFO3 visualizer
  • Pages now automatically switch along step recording
  • You can now use chord mode on only one part. When recording the chord pressing the first note below the split point will activate the chord mode on the lower part. Press the first above the split point to activate it on upper part
  • Voice Cycling have been reworked in "Poly Unison" mode
  • "Unison Detune" is now enabled for "Poly Unison" mode and disabled for Chord mode
Bugfixes
  • Recursive modulations are no more wrongly recalled on re-enabling
  • Fixed a bug where some "Preset volume" parameter value was not encircled in the "Preset Volume" menu
  • Setting LFO1 "Phase" knob to max value now starts the waveform phase at the end of it cycle
  • When knob catch is set to hook or scaled mode there is no more stuck "Tune" parameter when using the "Tune" knob after loading a preset
  • Fixed an issue where recording a motion on morphee on the 1A1 preset could lead on a broken patch on reboot
  • Sometimes moving Attack or Release VCF fader could stuck the screen and matrix. It is now fixed.
  • No more random freezes happens when switching presets
  • Setting a default sound designer name is now working
  • Gate knob display should now work properly whatever the menu you are
  • When using ARP no more unwanted low notes can trigger when playing high notes with octave range > 2
  • On display, in TAP or SCAN mode, X/Y point is now resetted when pressing Z axis without using the X/Y axis.
  • Fixed some zipper noise when modulating parameters with expression controls
  • AT section LED is now lit off when the unit goes in sleep mode
  • No mores stuck notes when playing too high notes with the arpeggiator
  • In ARP & Seq mode ratcheting policy is now the same between "poly" and "unison" and "mono" modes
  • Ratchet on a polyphonic step is no more only playing the first note of the chord
  • No more unwanted display when holding "Presets" and clicking the left and right panel arrow
  • When assigning and removing a modulation on EDIT A or EDIT B part, the matrix slot is no more lit in MODS section
  • "Voices" modulation source to Glide destination is now spread among voices
  • Bitcrusher gate level has been fixed for new presets. It is left unchanged for already existing presets
  • When a calibration failed, the unit restore the previous calibration as a fallback
  • You can now still hear sound through the "Phones" output after a calibration without to have to tweak the "Phones" knob
  • "Generate" function will no more adds modulations without any amount
  • Destination selection is now refreshed as soon as you click on a modulators matrix cell
  • On LFO3, when set on "Retrig" with a "Rate" set at minimum speed, no more unexpected artifact can be heard
  • "Master GlideTime" parameter is now labeled "Glide"
  • Fixed various bugs when using the Sample & Hold LFO mode with Poly & Mono Retrig Mode
  • Fixed sequencer issue where sequence can be stuck when playing with an external keyboard on lower part
  • ARP/SEQ now continue when using "copy to seq" function
  • Fixed Preset Name modification glitch if you set some space at the end of the Preset Name
  • Fixed a tooltips bug when resetting a pitch global amount with the reset amount shortcut
  • Mod Amount knob is now effective when morphee or ribbon visualizer are displayed
  • Fixed some display inconsistencies about the circled destinations in the modulation matrix when using the "compare" function
  • Fixed various clock issues when using it with external devices
  • Fixed an issue where Octave LEDs can being stuck after setting a Split Point
  • In "split" mode, when transposing "Lower Part" octave, octave LED are no more cycling between negative and positive octave shift
  • Sequencer now stop running while the unit is performing a calibration
  • Fixed a crash happening when using the sequencer while using the "morphee" and the "Seq Length" button in the same time
  • Fixed some calibration inaccuracy issues
  • Fixed a bug with chromatic glide where first note can be missed when pitch goes downwards
  • Fixed a bug where having a looping envelope(VCA, VCF ,MOD ENV) in lower part can shut voices on upper part
  • Fixed a voice stealing issue when using split mode with different poly allocation modes for lower and upper part
  • Fixed a ribbon issue when using maximum amount of modulation and reaching the end of the ribbon
  • Fixed some sound artifacts when turning fastly the "fine tune" knob while holding note
General Improvements
  • Increase encoder & screen responsiveness
  • Increase "Modulation Amount" knob accuracy
Posts: 9549 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Re: A big firmware update for the Arturia PolyBrute
Post by resistorman »
Arturia has turned into one of my favorite companies from their updates alone!
resistorman
Posts: 2869 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
You mean they left all that out! and it still worked!
Posts: 19405 Joined: Sat Jul 12, 2003 12:00 am
Post by sonics »
Bravo Arturia! I do like this modern gear that can be updated with firmware fixes, and almost always at no cost. I have a few devices that have been substantially improved since release. Some equipment is released too early and never gets fixed at all, however. :(
sonics
:bouncy:
Arpangel wrote: Tue Sep 19, 2023 9:19 pm You mean they left all that out! and it still worked!
:bouncy:
resistorman
