resistorman wrote: ↑Wed Oct 04, 2023 10:21 pm
Sounds interesting! Where can I get this plugin? My K-board hasn't sold yet.
Just google 'qunexus unleashed' and it'll take you to the Reaper Stash. The plugin works with both the KBoard and the Qunexus. It does not affect your standard firmware or settings. Documentation is included in the download.
What it does:-
Equalises all keys to provide an even velocity and pressure response. The internal pressure sensors have up to a 3:1 variation between sensors, and the standard firmware is pretty hopeless at compensating for this.
[I have been told that later units get calibrated using a pressure roller which may make them better; my two units are very early off the production line]
Supports two-dimensional gestures to control pitch and modulation on every key. Yes, you can wiggle the keys sideways to add modulation and yes, you can tilt the keys as well and yes, the algorithms used actually work; there's a little bit of technique in learning to 'roll' your finger over the key (see the documentation), but, hey, it's an instrument, like the violin, you gotta control it!.
Supports sophisticated pressure envelopes, polyphonic AT, portamento (you can do this with glissando as the white notes are all next to each other, so the software figures out your intention and lets you use them as a kind of 'ribbon controller' for big controllable pitchbends.)
Supports min/max velocity thresholds to make playing wide dynamic range instruments like piano much more controllable.
Supports a bias threshold so that you can, for instance, bring in a rotary speaker effect on an organ patch by using key pressure.
Allows the pitchbend nub to control both pitch and modulation simultaneously
This has turned my pair of qunexii into genuinely useful little keyboards which are unique control surfaces. There is nothing like them, especially the KBoard, for the price, and it's such a shame that KMI compromised excellent hardware with some very mediocre firmware. Still, they were lovely when I discussed some of the shortcomings and shared the SysEx messages that allow raw sensor data to be transmitted. Using this it was possible to overcome all of the limitations of the units, with the other advantage that because this now works as a plugin in Reaper, you can store the entire configuration of how you want the keyboard to respond in the project, thus matching the keyboard's response to the instrument you are controlling.
