ASIO4ALL problem
Re: ASIO4ALL problem
Is there a particular reason why you are not using the Behringer ASIO drivers?
ASIO4ALL has a specific use, if you are trying to connect two or more different bits of ASIO hardware to your PC and want to combine all inputs and outputs, but all to often it is found to be buggy and with very poor latency. Best avoided if at all possible.
I'd recommend using the hardware vendor's dedicated ASIO drivers.
Stu.
Stu.
- Moroccomoose
Frequent Poster - Posts: 568 Joined: Tue Apr 12, 2011 12:00 am Location: Leicester
+1 Behringer drivers!
- resistorman
When I last checked there were no ASIO drivers for the UMC22 which is why I always recommend that people go for the UMC0202HD which is probably about the cheapest interface that is actually usable for music.
ASIO4ALL creates more problems than it solves. I was wrestling with it for about 19 seconds earlier before I disabled it and plugged in a proper audio interface instead.
James Perrett wrote: ↑Mon Oct 09, 2023 3:46 pm When I last checked there were no ASIO drivers for the UMC22
Man, that is cheezy!
- resistorman
Shame, the UMC series are, err OK if you really can't afford anything better.
If you read the comments on the UMC22 on the Behringer site, people are giving five star reviews (so people see them) but are saying it really doesn't work on Win 11.
You aren't alone.
You aren't alone.
