(Warning! another "newbie" question incoming
So I have the following set up: Zoom L20 Mixer https://zoomcorp.com/en/us/digital-mixe ... trak-l-20/Adam T8V Monitors https://www.adam-audio.com/en/t-series/t8v/ and a range of Audix mics on an acoustic drum kit. No other links in the audio chain so to speak.
I have been working to "gain stage" the drum sound and have something I feel it pretty balanced and that doesn't "clip" even when all the mics are recording. (It's nudging @ -5Db)
When I play a recording back out of the speakers (all channels set to 0Db including the Master output) I get a decent clean sound BUT I was getting @ 60Db reading on my phone app, and I had heard people say a good level to listen to Studio monitors is @ 80Db (and honestly I wanted a it more volume too)
So rather than alter any of my carefully constructed "gain levels", I altered the Db levels on the backs of the speakers, so that I got more oomph and something approaching 80D from them.
What I then noticed was that with all the faders set to 0Db including the Master fader I hear a hiss from the speakers.
BUT...
IF I pull all the faders down to - infinity (except the Master) the hiss goes.
Also...
If I play some properly recorded music (in this case the Wonderful Alison Krauss and Robert Plant's new album which I'd highly recommend btw) at loud volume (with all other channels at zero) I get NO hiss.
BUT
If I slide the faders of the channels back to 0 the hiss returns..
So, (finally!) I get to the questions:
What might the root causes of this?
What is the best way to get the levels from the kit I want plus good output levels (@ 80Db) from the speakers without hiss creeping in?
I do hope that all makes some sense?, and many thanks for any thoughts you might have on this type of issue?
