Squishbox
Squishbox
Post by MarkOne »
Well, the kit parts have been sat on my desk for well over a month, but I got some free time yesterday so made a start.
It’s been possibly decades since I soldered PCBs, but given that back in the day that was my life, I really don’t remember the need for such a strong light source, a pair of reading glasses and a bench magnifier! Old age! [sigh]
I’ll try and take a few pics along the way, and post them up, and hopefully some audio later on.
MarkOne
My Music on Apple Music
My Music on Spotify
Re: Squishbox
Post by MarkOne »
And so it begins…
MarkOne
My Music on Spotify
Re: Squishbox
Post by MarkOne »
MarkOne
My Music on Spotify
Re: Squishbox
I do like a nice build thread. :thumbup:
Posts: 29713 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Squishbox
Post by BJG145 »
Excellent.
I still have one of these sitting in a bag since your original post. But I did at least order a soldering iron on eBay the other day. (I scrutinised the vintage Weller offerings, then shrugged and picked up some new Parkside tat for a tenner.)
Why people don't just supply pre-soldered pin headers, I'll never understand. Still saving for the Dobot.
Posts: 8083 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Re: Squishbox
BJG145 wrote: Sun Oct 22, 2023 4:54 pm Excellent.
in a word... Packaging.
There was at least one rather dodgy looking joint in that vid :tongue:
Posts: 20879 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Squishbox
Post by BJG145 »
Folderol wrote: Sun Oct 22, 2023 5:07 pmThere was at least one rather dodgy looking joint in that vid
(Well spotted. I commented on that but I don't think it was approved.)
Re: Squishbox
Folderol wrote: Sun Oct 22, 2023 5:07 pm There was at least one rather dodgy looking joint in that vid :tongue:
I saw no spliffs?
Re: Squishbox
There would be certain components e.g. transistors, that could easily be fried by the length of time that Dotbot applied heat to the pins. An application of flux paste would probably allow for a much shorter soldering time. You could manually solder each pin in about a second, whilst the dotbot took 3+ seconds.
Re: Squishbox
Post by BJG145 »
Wonks wrote: Sun Oct 22, 2023 5:16 pmI saw no spliffs?
You can tell from the smoke.
Pics or it didn't happen. :D
Re: Squishbox
Post by BJG145 »
I thought I'd spend the morning building my Squishbox kit. I confidently ignored the advice to follow all the steps in the correct order, and was pleased with progress until I reached the last step of the electronics assembly and realised I'd soldered this pin-header into the wrong side.
Well, you'd have thought the "top side" was the side with the logo on it, wouldn't you. :roll:
Unfortunately this is quite a major blunder; I don't think I've got the skill, tools or patience to try and remove it again, so this will likely remain as a breadboard project once I've summoned the will to continue.
Re: Squishbox
Post by BJG145 »
It might be OK...I think one of these will get me back on track. Hopefully.
Re: Squishbox
This is a great video on how to desolder multi-pin components. I’ve recently used it on some switches and it worked just as described.
https://youtu.be/Vou2xlJkuoU?feature=shared
(there is a part 2 that carries on with more awkward components).
Using extra flux is important in a situation like this, so get some and use it. The stuff he recommends doesn’t appear to be available any longer, but any ‘no-clean’ flux should be OK.
For the thick copper wire, I used the earth wire from some solid core twin and earth cable I had laying around.
Re: Squishbox
That's brilliant, good find Wonks. :clap:
Re: Squishbox
Post by ajay_m »
You need one of these. They are the gold standard for removing components and I promise you they can remove wrongly soldered headers too.
https://thepihut.com/products/adafruit- ... rYQAvD_BwE
ajay_m
Posts: 1671 Joined: Mon Jan 16, 2017 7:08 pm
Re: Squishbox
Post by ajay_m »
And further to the previous post I purchased a job lot of really cheap 4 digit X 14 segment displays without realising that for some weird reason two digits were red and two amber. But a session with The Engineer soon removed two displays from each board, allowing me to create some nice all red and all amber displays for a couple of quid each.
ajay_m
Re: Squishbox
ajay_m wrote: Sat Nov 04, 2023 6:11 pm You need one of these. They are the gold standard for removing components and I promise you they can remove wrongly soldered headers too.
I have one of those and whilst good, I couldn't unsolder a six-pin switch from a through-hole PCB with one, despite using extra solder and extra flux, whereas the video method worked perfectly and in much less time than I spent with a solder sucker and desoldering braid etc.
Maybe with a lot more practice I could do it all with a sucker, but I want to do it now, not in 6 month's time. I used to do it just with a sucker on single-sided boards long ago with leaded solder, but through-hole and lead-free always leaves enough residue when I do it to stop the component from coming loose.
Re: Squishbox
Post by BJG145 »
Another morning of cursing, burns, and toxic fumes, and the wretched thing is nearly done. :roll:
The last time I tried soldering together an electronics kit was a 300 baud modem from Maplin when I was at school. It never worked. This has cured me of electronics kits for life; it's far too fiddly and annoying. It's different working on your own creative/original stuff, but putting other people's boxes together isn't worth the effort. I'd rather just buy something that's finished.
Re: Squishbox
I don't think I've ever built any kit without making some 'personalising' modifications :lol:
Re: Squishbox
Post by BJG145 »
MarkOne clearly made better progress in 90 minutes a fortnight ago than I made this weekend, so I'm not sure why the updates stopped. He didn't even finish the tinning. :-|
Anyway, my cable arrives Tuesday. I'm hoping to have my Squashedbox running then, with the screen at a debonair angle to include this impromptu addition. So it's game on.
Who uses soundfonts nowadays...? Well, you might be surprised. They're used by the Digigurdy, for example, so I'm hoping to set the cat among the pigeons in the Midi hurdy-gurdy community with this build.
Re: Squishbox
Post by MarkOne »
BJG145 wrote: Sun Nov 05, 2023 7:43 pm MarkOne clearly made better progress in 90 minutes a fortnight ago than I made this weekend, so I'm not sure why the updates stopped. He didn't even finish the tinning. :-|
Sorry. Slow progress here I’m afraid, a combo of business travel, a gig, some well earned down time on Dartmoor and then a stinker of a cold!
MarkOne
My Music on Spotify
Re: Squishbox
Fascinated to hear how these turn out! :clap:
Re: Squishbox
Post by BJG145 »
Cable arrived, spent the evening tinkering around with Pi OS, and...
...doesn't work. I give up.
Re: Squishbox
BJG145 wrote: Tue Nov 07, 2023 9:36 pm Cable arrived, spent the evening tinkering around with Pi OS, and...
:shocked: Give ... Up :crazy:
Does not compute!
Re: Squishbox
Post by BJG145 »
I'll wait and see what happens with MarkOne's anyway...!
