Hello Forum
Im having trouble sourcing replacement Rubber Contact Strips for my Korg Microkorg. I contacted Korg but they were unhelpful .and so far im not having any luck finding a UK supplier. Any help will be very useful
thanks in advance
Mike
Korg Microkorg replacement Rubber Contact Strips.
mdsc
Re: Korg Microkorg replacement Rubber Contact Strips.
You might struggle in the UK. Korg seem to classify the whole keyboard as one part number (420006800).
From the US:
https://syntaur.com/keyboard.php?keyboa ... _MicroKorg
Have you been through this cleaning process?
https://documents.cdn.ifixit.com/pdf/if ... 141_en.pdf
From the US:
Ive done a light clean with servisol may do it again if I can t get the parts
mdsc
Hi, just in case if your are still searching for replacement rubber strips.
Just check this site out:
https://notaufnahme.org/korg-microkorg- ... pare-parts.
There you will find many replacement parts.
Good luck Frank
Good luck Frank
