Short version of my question:
Should I treat Impedance Balanced Connections in exactly the same way as actual balanced connections (whether transformer or electronically balanced)?
Longer version of said question:-
I have a couple of Behringer RX1602 line level mixers which I've always connected directly to all my synth gear (or via the odd pedal or two) and then onto a FoH or studio mixer, either via a DI box (Radial JPC or Behringer DI800 / DI4000) or simply via a couple of mono TR cables in the studio, if the runs were short enough.
Because I'm finally dumping my Behringer MX9000 desk (it's started to play up a bit too much - failing channels and failing routing - and takes up too much studio real estate these days, given my own composing/playing needs) I decided to patch the RX1602's into the Behringer PX3000 (balanced) patchbays (patch-bay? Hyphenated?) so I can add in effects pedals and other such goodies at a whim.
However, I'd always thought of the Main Outs on the RX1602 as (TR mono jack) unbalanced outputs ... but I consulted the manual and it stated TRS jacks. "Hmmmm, that's a l'il bit weird", I thought! This got me thinking. I initially suspected a misprint as the spec sheet at the rear of the manual clearly said the outputs were unbalanced ... and that's how I'd used them in the past, without much trouble.
Nevertheless, a bit of digging around online mentioned something called "impedance balanced" - it's in the RX1602 v2 manual spec sheet at the rear of the 'new' User Guide - which I'd never heard of. It seems it was something of a marketing ploy by Mackie in their early days, something which Behringer (unsurprisingly) 'borrowed' as it has some definite signal transfer benefits. Unfortunately, I'm finding it hard to separate the fact from the BS and understand precisely what the benefits (and downsides, if any) are! It also means I'm unsure how to connect it to the patchbay.
That's where you wonderful people come in...
There's a lot of jibberish concerning this online - marketing hyperbole, sales rhetoric, amateur opinion, guesswork, etc. - so I thought I'd seek a definitive clarification from the one-and-only expert on all such matters, namely Mr Robjohns!
More seriously, what I would like to know is whether I should connect these RX1602 sub-mixers to my patchbay using stereo TRS balanced interconnect cables or via the mono TR leads I've used in the past?
I try to use balanced cables/connections everywhere I can to alleviate any common mode noise but what I don't wish to do here is introduce any future problems (it took aeons to remove all ground loops from my setup years ago) by making any 'common sense' assumptions based on my obvious ignorance.
So, any and all help appreciated!
Thanks in advance,
Steve.
Pages 12 and 18, if anyone's interested:
https://mediadl.musictribe.com/media/PL ... 602_WW.pdf
and the patchbay:
https://mediadl.musictribe.com/media/sy ... 673246.pdf
