But I'd also like to use it with lavalier microphones for recording some dialogue, as well as recording some music from either a mixer or some synths directly. And this is where things get confusing to me.
The Zoom F3 only has XLR inputs. Most lavalier microphones are 3.5 mm jacks. So I'll need some sort of adapter.
Many lavalier microphones don't have their own power supply, and will require a bit of power from whatever they're connecting to. As an example, I have the Sony ECM-LV1. But will a regular XLR to 3.5 mm adapter be able to supply a lavalier with power? Or do you need to get some special (and no doubt more expensive) adapter for that?
The Sony ECM-LV1 is also a stereo lavalier, and it seems the Zoom F3 XLR inputs are mono, so you'd need to use both to get stereo sound. So I guess I'd need 2 x XLR adapters, then a 3.5 mm TRS female to 2 x 3.5 mm TS male splitter cable (which doesn't seem that common; the reverse seems a lot more common, with 3.5 mm male to 2 x 3.5 mm female). Would this work? Or would the splitter cable somehow get in the way of the power needed?
For synth recording, I'm guessing I'd need something similar if I'm looking to have stereo sound. But, I'm guessing they would work fine with "unpowered" XLR adapters (presuming there's a difference), as the synths and mixer are already powered by themselves.
I've tried googling and looking into this, but haven't found many answers. Which is surprising, as the Zoom F3 seems to be a popular unit, and I'd imagine a lot of people would want to use them with lavaliers given its size.
Thanks a bunch to anyone able to provide some answers!
