Cubase Elements 13 - where to install stuff?
Post by The Paul meister »
Hi everyone,
I've downloaded the Steinberg Download Assistant to try the Cubase Elements 13 demo. I've installed the Cubase LE AI Elements 13.0.20 Application to my internal SSD. I'm wondering what I can put on my external SSD.
Am I right in assuming that the HALion Sonic 7.0.20 Instrument (814.75MB), and the Groove Agent SE 5.1.20 Instrument (171.35MB) both need to be on the internal drive? And everything else can go on the external?
And when I install everything on to the external drive, what folder do I have to create to put it in?
Thanks, Paul
The Paul meister
Posts: 529 Joined: Tue Feb 28, 2006 12:00 am
Re: Cubase Elements 13 - where to install stuff?
Post by Stuart79 »
It will certainly work doing it that way. I have a similar arrangement for the full version of Cubase. All samples and whatnot are on a separate storage drive. (I don't think this has special naming requirements. I just created a folder called 'Steinberg' and directed the installer there.)
There's a separate application called Library Manager that lets you move all the Steinberg content around easily after the fact. See here:
https://helpcenter.steinberg.de/hc/en-u ... nd-Content
Stuart79
Posts: 175 Joined: Sat Jan 29, 2011 12:00 am Location: Cambridge, UK
Thanks Stuart
The Paul meister
Hi Stuart,
Thanks for the link about the Library Manager.
Perhaps I should have phrased my question more simply in the first place:
Which parts of the installation need to be on the internal drive, and which on the external?
Cheers, Paul
The Paul meister
Post by Stuart79 »
I'm no expert. I can only speak from my own experience, but the way you expressed it in your opening post is how I'd do it. Cubase plus instruments on the internal drive and any content on an external drive.
Stuart79
Ok, thanks Stuart :)
The Paul meister
Post by Kwackman »
Stuart79 wrote: Mon Jan 08, 2024 8:32 pmCubase plus instruments on the internal drive and any content on an external drive.
Same here, using the already mentioned "Library manager"
Kwackman
Posts: 3687 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by sonics »
The system drive is preferable for the instruments, yes, since it's usually the fastest drive in a system. It's when you start using large libraries you'll usually need to install them elsewhere otherwise you can run out of space, as you know! I note that Cubase Elements is advertised as coming with 20GB of sounds; presumably the "everything else" you mentioned?
If you record a lot of audio in your projects, using external storage (and making regular backups) is good practice, too.
sonics
