DAW faders linear or logarithmic?
Post by whitebaron »
Are DAW faders linear or logarithmic? I know that dB are logarithmic but I can’t get my head around faders. It seems that on analog mixers they are logarithmic but not on DAW?
whitebaron
Posts: 1 Joined: Tue Jan 23, 2024 1:34 pm
Re: DAW faders linear or logarithmic?
They are linear, in that they physically move in a straight line.
They are logarithmic in that the distance vs audio signal voltage gain/attenuation alters in a logarithmic ratio.
DAW faders are designed precisely to emulate physical analogue/digital console faders in normal operations.
Posts: 42769 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Though with some DAWs (e.g. Reaper) you can change that behaviour in the options.
Why you'd want to is a different question but... ;)
Posts: 28798 Joined: Sun Jul 05, 2015 12:00 am Location: York
Yeah but! I find with some faders the movement speed is NOT linear with position. That is they seem to zoom out of control at extremes of travel.
Posts: 18496 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by Kwackman »
ef37a wrote: Tue Jan 23, 2024 4:48 pm Yeah but! I find with some faders the movement speed is NOT linear with position. That is they seem to zoom out of control at extremes of travel.
Which DAW is that?
Kwackman
Posts: 3565 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Kwackman wrote: Tue Jan 23, 2024 5:10 pm
Which DAW is that?
Samplitudes Pro X 3 and 6.
My DAW faders default are dB for audio and 0-127 linear for MIDI
Posts: 4734 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
