Limiting for Social Media
Post by apaclin »
Hi guys, what's your limiting options when you export audio for reels, shorts and tiktoks? I always limit to -0.3 dBfs, but I noticed heavy distortion in one of my reels: https://www.instagram.com/p/CVYb0bAM5YE/
So after exporting audio I import it to a video editor (Final Cut) and don't limit it again.
What's the right approach with social media?
apaclin
Posts: 159 Joined: Wed Dec 16, 2020 5:00 pm
Re: Limiting for Social Media
I normally limit to -1 dBFS, which doesn't seem to get too badly mangled by most compression algorithms. I think if you want to play it properly safe then the advice is generally -3dBFS.
Posts: 29713 Joined: Sun Jul 05, 2015 12:00 am Location: York
That distortion doesn't sound like a result of limiting to me. The guitar sounds fairly clean and the problem seems to be more with the backing track.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
I agree with James. The guitar sounds OK but the backing track is very squashed and distorted.
Post by apaclin »
James Perrett wrote: Sat Jan 13, 2024 2:42 pm That distortion doesn't sound like a result of limiting to me. The guitar sounds fairly clean and the problem seems to be more with the backing track.
No, the backing track is perfectly fine. Here's the clip which is not uploaded: https://disk.yandex.ru/i/L0iqkWfpt8CDSg
Also, just noticed that it turned stereo into mono, which is odd, because even previous reels are in stereo, so apparently the bug happened.
apaclin
Post by yeroc »
Perhaps its a data limit when you uploaded it? i.e. while on a bandwidth limited network, a setting that was turned on for data compression within Instagram?
yeroc
Posts: 219 Joined: Tue Jun 16, 2020 5:54 pm
Post by apaclin »
yeroc wrote: Sat Jan 13, 2024 6:00 pm Perhaps its a data limit when you uploaded it? i.e. while on a bandwidth limited network, a setting that was turned on for data compression within Instagram?
Just checked in the settings, yeah, there is a setting "upload in the highest quality" which was turned off, so most likely that affected it.
apaclin
apaclin wrote: Sat Jan 13, 2024 5:35 pm Also, just noticed that it turned stereo into mono, which is odd, because even previous reels are in stereo, so apparently the bug happened.
I wonder if something simply added the two stereo channels together to make mono? That would increase the level by 6dB.
Post by hz37 »
apaclin wrote: Sat Jan 13, 2024 1:59 pm Hi guys, what's your limiting options when you export audio for reels, shorts and tiktoks?
I always aim for -16 LUFS loudness for social video's and podcasts, unless specified otherwise. Some services require -14 LUFS. The true peak I usually keep way conservative, around -3 dBTP. There is zero reason to max peaks out all the way to -0.3 dBFS. A properly mixed and mastered social video doesn't have that much loudness range because of its purpose/audience, so you could easily mix it around -16 LUFS and have a ceiling of -3 dBTP or even lower. One thing I usually do these days is remove phase alignment issues; a -16 LUFS mix can swing back and forth more than needed without phase alignment. RX Connect (the standalone editor) does it all for you. I would really recommend aiming for a loudness standard instead of a peak measurement. My clients love the loudness consistency of my mixes and the human hearing just doesn't register peak levels the way a normalizer does.
hz37
Posts: 49 Joined: Sun Apr 16, 2006 12:00 am Location: The Netherlands
And there I was naively thinking that 'Limiting for Social Media' was going to be about how to waste less time on it, and spend more time actually making music.
:beamup::headbang::bouncy:
