Korg OPSIX etc now MKII and as modules
Re: Korg OPSIX etc now MKII and as modules
Post by t-sun »
So the new versions appear to use a newer version of the RPi Compute Module that the first versions used, so they bumped up the voices. Frustratingly the Opsix is still monotimbral, so you get 64 voices of the same thing. Racking them is also a bit weird because the outputs are still on the rear, which becomes the top, and they can't be rotated.
t-sun
Posts: 264 Joined: Mon Jan 18, 2021 6:31 am
yep, like so many digital synths these days, its not multi timbral. Seems a big omission.
The opsix can have its operators limited in keyrange, so you can achieve different sounds across the keyboard that way but its not anything like the old blofeld which can do patch/channel.
Looked at this, not enough dedicated knobs for operator functions, something like Mega FM is a better bet for this, although unlike the OP6 it cant import DX7 sounds, you can’t have it all.
The super power of the OPSIX is that the operators can be anything, they also do FM. The Algorithm is user defineable.
t-sun wrote: Sun Feb 04, 2024 8:05 am .. Racking them is also a bit weird because the outputs are still on the rear, which becomes the top, and they can't be rotated.
The sockets appear to be recessed
