Focusrite Scarlett 6i6 Monitor knob
Post by p3go0 »
I've just plugged in my new Focusrite Scarlett 6i6 for the first time. I get sound in the monitors, but the monitor knob on the hardware doesnt affect the sound at all. The headphone knobs seem to work fine though. I cant find a way to enable HW control in the Focusrite Control. What am I missing?
p3go0
Posts: 3 Joined: Sun Sep 23, 2018 10:44 pm
Re: Focusrite Scarlett 6i6 Monitor knob
If you post a screen shot of how you've got the Scarlett MixControl page set up, along with confirmation of what's plugged in where that be helpful in working out what might need tweaking. :)
Posts: 29717 Joined: Sun Jul 05, 2015 12:00 am Location: York
Someone in "Another Place" had exactly the same problem. Turned out they had not plugged the monitors into the main 1&2 line outs.
Politely told to RTFM...
Is it a 2nd Gen 6i6? If not the G2 mix software can still be used with the Mk1 I understand and is much improved?
(I am bloody ballistic that it WON'T work for my 8i6!!)
ef37a wrote:Someone in "Another Place" had exactly the same problem.
That someone was the OP for this thread - it is a pity they didn't have the decency to come back to let us know that it had been solved.
Post by Willpearson »
What does RT mean? Seems important that I avoid being told this :)
So if I'm playing keys and using in ear monitors, what's the 'best' way to set up my 6i6.
Main output from keys/mac going out of output 3-4 to desk. 1-2 used for my monitoring?
Aux send from desk into, say, input 3.
Can I just plug my in ears into a mini-jack to 1/4" adapter and stick it in output 1?
Then could the big silver knob let me control the mix between keys/mac and the aux send?
Clearly, I need to get reading and watch some more videos. But if someone has the patience to answer I'd be very grateful !
Willpearson
Posts: 4 Joined: Tue Feb 06, 2024 9:56 am
Willpearson wrote: Tue Feb 06, 2024 10:03 am What does RT mean? Seems important that I avoid being told this :)
Dave seems to feel the familiar 4 letter acronym is still too long. :roll: I believe he meant RTFM
I'm not familiar enough with the 6i6 to answer your routing questions.
But I can tell you that plugging headphones into output 1 won't work very well. Its a mono balanced output, whereas headphones need a stereo unbalanced output.
What's wrong with using the dedicated headphone outputs and using the 6i6 software control panel to build whatever monitoring mix you desire?
Hugh Robjohns wrote: Tue Feb 06, 2024 10:30 am
I did type RTFM unless you have changed it?
Ermmm, yes, that would make sense. Thanks.
Willpearson
ef37a wrote: Tue Feb 06, 2024 1:13 pmI did type RTFM unless you have changed it?
No, you typed "RT..." as per the OP's quote. After replying to him I changed your post to avid further confusion for other readers.
Hugh Robjohns wrote: Tue Feb 06, 2024 4:04 pm
I'm confused now. What "OP's quote"?
Indeed. The OP was p3go0, whilst the ‘RT’ was quoted by Willpearson.
So maybe a RTFT for Hugh? :D
Clearly we need a PIR to establish some CSFs and work out what the KPIs to meet them are.
Document all this in a BRD ready for an SDD and we should be G2G.
(Only one of these isn't a real thing in my job!)
