- Creative Titanium X-Fi
- ECHO Audiofire 4
For the internal card I really just used it for default windows sound for general applications connected via SPDIF to a set of small surround speakers, these can handle dolby sound from Power DVD. The Audiofire was connected to studio monitors. I found it an advantage to separate the two uses as there was a time when windows sounds/alerts would reset any sound device while you were using it in an application.
So, the following could be choices for a new PC...
- Creative Sound Blaster Z SE
- RME HDSPe AIO Pro
And for the RME expensive option the card does not look like it has any shielding, can it work OK in a modern PC? Again driver updated in 2020 and maybe no Windows 11 support.
I'm wondering if the time has come to give up and try onboard sound and hope it is fine for general usage. I will still have the external interface for proper audio usage.
