SSL12 Interface Keeps Disconnecting
Post by christmas28 »
A week ago I bought a new SSL12 audio interface, and although everything else seems to be working well, when I'm in my DAW and I record using a microphone with +48V phantom power, the SSL12 keeps disconnecting. I believe it has something to do with the +48V, but I have no idea what to do to fix it. Any help would be really appreciated!
christmas28
Posts: 1 Joined: Sat Oct 07, 2023 2:12 pm
Re: SSL12 Interface Keeps Disconnecting
Are you connecting it to a USB2 or a USB3 port on your computer? There is a cryptic comment on SSL's web page that implies that it uses USB2 for audio data but needs USB3 for power. If you are trying to use it with a USB2 port then you may not be giving it enough power.
Posts: 16381 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
It says:
“USB bus-powered audio interface for Mac/Windows - power is provided by USB 3.0, audio via the USB 2.0 protocol”
Posts: 18707 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Though the manual says “SSL 12’s power is based on the USB 3.0 specification (900mA) so ensure you are connected to a USB 3 port and not a USB 2 port.”
So SSL really need to tidy up their website.
If you are on Windows you want to ensure that there aren’t any USB power saving modes in operation (this may also apply to
Macs but I’m a PC person so don’t know).
Post by ajay_m »
900mA is certainly pushing it, although the spec is 1A. The problem here is that most USB cables have pretty thin cores and the voltage drop at these sort of currents could start to be an issue. I would look at getting a USB cable which is intended for high power use - check out reviews etc. to find something reputable, and keep the cable as short as possible.
ajay_m
Posts: 1479 Joined: Mon Jan 16, 2017 7:08 pm
Post by detroitT »
Wonks wrote: Sat Oct 07, 2023 3:00 pm It says:
Hence the SSL ‘s need for a power supply insert via the usb-c cable.
M1Max ultra 100v cable snapcrackle @96khz
detroitT
Posts: 1 Joined: Tue Jan 19, 2021 1:49 pm
