I had all my Cubase projects in a local E: drive SSD. I then uploaded (dragged and dropped) my E:/ drive to DropBox (1 TB of info - Cubase Projects, and a load of other stuff like Sample Tank samples, etc.).
Now my local Windows File Explorer folder structure is changed - in E:/ drive there is now a new highest level folder ,called "Dropbox", and I can view the other files and folders (including those with Cubase projects) if I double click on that Dropbox folder. And if I want to open a Cubase project called greatsong, I just point Cubase to that E://DropBox/Cubase Project greatsong/greatsong.cpr file.
Thanks for following - here's my question: Am I accessing my Cubase project greatsong from the Drop Box cloud, or my local E:/ drive?
And if it did happen to be accessed from the cloud -would that be a bad thing?
I think I'm accessing the project from the local E:/ drive, because in my W10 File Explorer the .cpr file has a solid green circle with a white check mark, which someone on line said meant it was both local and online.
Would anyone have any insight into where I'm actually accessing my .cpr file from now that I've done that drag'n'drop of the entire E:/Drive to DropBox?
Thank you!
