Hugh, I forgot to mention, I chucked it through the window, jumped on it, and it still worked! so my repair was a definite success, and I take back any misgivings I had about Moog build quality.
Eddy Deegan wrote: ↑Thu Mar 07, 2024 10:29 pm
Tony, when I next visit I'll bring the Hydrasynth Deluxe and the UDO Gemini. I really want to see what you make of them. I think you'll like the Hydrasynth sound but I suspect the Gemini will be a revelation both in sound and operation. There are no menus, it doesn't even have a numeric display and there's a knob, button and/or slider (two, in many cases) for everythingArpangel wrote: ↑Thu Mar 07, 2024 6:51 pm ... look at the tank itself, haven't done this before, noticed a really bad dry joint on one of the phono sockets, buzzed it through and confirmed it, re-soldered all of them, all OK, been working all day, moved it, put it down "heavily" all OK, no issues, I can't get it to malfunction.
So that cable you suspected before maybe wasn't the problem after all! Well, if resoldering that dry joint on the tank resolves the issue then I'm happy to hear it (not the spring reverb itself though; like Elf I'm not a fan of spring reverb on synths)
I look forward to this Eddy, big time.
Although, im not in anticipation of what they might sound like, it's more about how they push me, or guide me, offer me? musical starting points, how they suggest ways to go, the sound isn’t so important, as that’s a given.
