Lostgallifreyan wrote: ↑Sun Mar 31, 2024 11:52 pmJames Perrett wrote: ↑Sun Mar 31, 2024 7:36 pmLostgallifreyan wrote: ↑Sun Mar 31, 2024 7:27 pm If you want them I can send them to you. It could save you some time.. I've not tested any yet, but I will enter that rabbit-hole later, at my own expense, and with some red pills.
Thanks for the offer but the file name was enough to allow me to find them. I'll let my son know about them.
This might give you pause..
Just installing Behringer's drivers today has ruled out Behringer for general Windows use. They don't even care to support their own drivers (or we'd not need Wayback to find them), and installation was like the bad old days of driver hell in W95. They kept demanding sysfiles that were IN the system, and that's when they didn't lock up WXP trying, even with driver versions intended for that OS.
I think you are asking too much. There was obviously a good reason why Behringer decided not to supply ASIO drivers for that range of interfaces and you've just found it! If you want ASIO then use an interface that supports it rather than try to cobble something together from stuff you've found on the net. As I said in my previous post - if you want proper ASIO then you will need a Behringer UMC0202HD or better - in my experience the drivers for that install with no problems.
Edit to add:- those cheap Behringer interfaces also have other issues which limit their usefulness for serious work in my experience.
