De-Essing Male Vocals?
Post by Jathon Delsy »
Well, what about it folks?
How do y'all feel about de-essing male vocals?
I'm specifically interested in my vocal, which is a pretty average English guy light lyrical vocal, somewhere between Lennon and McCartney.
Or, is it an open question, like asking how long is a piece of string?
Still, I know there's a wealth of learned opinion among you folks!
Jathon Delsy
Posts: 205 Joined: Fri Dec 05, 2014 12:00 am Location: London, England.
Re: De-Essing Male Vocals?
Post by tacitus »
De-essing male vocals was much more of a job back in the days when they still used long esses …
I know some of us here are old enough for that comment.
tacitus
Posts: 1584 Joined: Mon Feb 04, 2008 12:00 am
tacitus wrote: Fri May 03, 2024 8:30 pm De-essing male vocals was much more of a job back in the days when they still used long esses …
I think we should bring back the long ess. It adds a sophisticated flourish to our prosaic melieu!
Jathon Delsy
Post by amanise »
Well, I de-ess mine where I think it needs it. My esses are as good as any girls esses! I do as little as I think I can get away with because its painful. I use a de-esser outboard which is part of my compressor/limiter set to 'male' and then I use good old clip gain settings and volume envelopes in my DAW for the many that get through. There's no essssscape!
Ho Ho Ho :-|:bouncy:
amanise
Posts: 5267 Joined: Thu Jan 26, 2023 1:45 pm
Adrian Manise
Faith in Absurdity :crazy:
A Hazelnut in every bite :wtf:
Post by sonics »
Like anything similar, it's an engineering/production decision. So yes/no/maybe/lots/twice etc.! :lol:
It'll depend on singer, technique, microphone, recording (compression/EQ etc.), music, arrangement and mix.
So my answer is the always reliable...it depends. (But mostly yes, at least a little.) Use your ears and if you're not sure, reference.
sonics
Post by Philbo King »
I've gotten into the habit of singing off-axis into the mic by 30 to 45 degrees. LDC mic, cardoid pattern.
I haven't needed a de-esser at all since I started doing it.
Philbo King
Posts: 383 Joined: Thu Oct 11, 2018 10:07 pm
Post by Zukan »
De-essing is de-essing, be it for male, female, snakes...no diff.
I de-essed a cobra once. Barely talks nowadays.
Zukan
1-2-1 Tuition
Vocals of any persuasion sometimes need de-essing, sometimes don't. It's not a given.
If they *do* need de-essing, then heading straight to a plug-in is not always the best option IMHO. I'd say that a bit of snipping and editing can produce subjectively better results. Sometimes multing and filtering is a good option.
As the good chap above said - it all depends...
Post by Kwackman »
Zukan wrote: Sat May 04, 2024 8:51 amI de-essed a cobra once. Barely talks nowadays.
:bouncy::thumbup:
Kwackman
Posts: 3687 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Zukan wrote: Sat May 04, 2024 8:51 am I de-essed a cobra once. Barely talks nowadays.
:bouncy::bouncy::lol::lol:
Post by Tim Gillett »
Jathon Delsy wrote: Fri May 03, 2024 6:58 pm
...How do y'all feel about de-essing male vocals?
I'm specifically interested in my vocal, which is a pretty average English guy light lyrical vocal, somewhere between Lennon and McCartney...
Esses are one of the consonant sounds including the t, f, c sounds. Often they seem too prominent because the vowel sounds from the throat are weak by comparison. Learning to sing with more power and control - such as in performing live to an audience without the help of a microphone - can as a side benefit help make the "ess" issue less of an issue.
Tim Gillett
C'mon folkth I'm theriouth about my de-ething!
Jathon Delsy
Post by Dynamic Mike »
Personally I cut the esses in Cubase and copy them onto a separate track. Then I de-esse them quite savagely, reduce their volume on the original track and blend the effected ones back in. It means the rest of the original track is unaffected and the final result retains some character.
It's probably the wrong way to go about it but it works for me and it's non-destructive, albeit a bit time consuming.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
Post by resistorman »
Some of my favorite plugins for vocals and lots of other things are the PSP Old Timer Multiband, Vintage Warmer 2 (in split mode), and Eventide Split EQ, all of which can control problematic frequencies. I use the EIOS E2deesser too. I leave snakes alone.
resistorman
Posts: 2987 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by ConcertinaChap »
For tricky esses I use Melodyne. You can cut the note to make a blob encompassing just the ess and then reduce the amplitude. You're not going to want to do that too often but for the odd example it gives you great control and precision.
ConcertinaChap
Posts: 15240 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Easy! I just spend about three quarters of my total mix time on it and still end up with something I'm not happy with.
_e _rouble i_ i__ _o ea_y _o overdo i_ _o you can'_ make ou_ a word.
Posts: 20887 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Dynamic Mike wrote: Sat May 04, 2024 5:03 pm Personally I cut the esses in Cubase and copy them onto a separate track.
One of my approaches too.
However, I've recently found that the new vocal strip insert in Cubase is pretty much doing the job for me now. It maybe wouldn't work in every scenario, but I'm impressed so far.
