Wireless headphone latency
Post by FrankF »
I'm using a multitracker, not a DAW. :tongue:
My Sennheiser wireless phones (Rs 160) exhibit sufficient latency to preclude them from recording tasks, so I'm wondering: are there wireless phones out there that are low latency?
I didn't even know these not-cheap 'phones had latency until I tried recording with them.
FrankF
Posts: 594 Joined: Fri Sep 13, 2002 12:00 am Location: La Vendée, France
Re: Wireless headphone latency
Those particular phones use a lossless compression system, so the sound has first got to be converted to digital, then compressed, then sent/recieved, then uncompressed and then converted back to analogue.
I’ve got no idea why they do the lossless compression unless its simply to make the bandwidth used within in the 2.4GHz band as small as possible. But they really are meant for listening, not mixing.
But that’s going to add to the standard wi-fi latency (which is normally between 1 and 3 ms for stage gear).
So I’d look at phones without any compression system (for lowest latency), or analogue transmitter technology (for no latency). But I will admit to having no idea what’s currently out there.
Post by MarkOne »
The latest incarnation of Bluetooth, Bluetooth LE gets real world latency down in 15ms territory. I’ve read that theoretical latencies of around 7-8 might be achievable.
You are down to audio interface territory.
But in your situation you’d need a BT LE transmitter as well. Don’t know what’s out there though.
MarkOne
My Music on Apple Music
My Music on Spotify
An IEM transmitter/reciever combo with standard phones is one option.
Post by FrankF »
Thanks for the suggestions: the IEM + headphones option looks interesting.
I'm living in a student cupboard for a few more months, and I'm tripping over guitar and headphone cables, whence my desire to reduce cable pollution whenever I engage in some nifty guitar-pedal footwork.
FrankF
What's your ceiling like? I realised my cable situation could be vastly improved when I realised that I had a set of beams over my head and cabling could go up and over rather than down to the floor.
Post by FrankF »
Sadly beamless. :thumbdown:
I guess I could try sitting down: hadn't thought of that!
FrankF
Post by sonics »
I'm not sure you'll improve much on what you have, even with Bluetooth AptX LL. Something like the Audeze Maxwell gets the latency down low enough, but you need to use the transmitter dongle connected to a computer AFAIUI.
I'd recommend staying with a cabled solution for the headphones.
sonics
Post by Tudder »
In my opinion latency can indeed be a significant challenge, especially for tasks like recording where timing is crucial. While the RS 160 model may not meet your needs, there are wireless headphones available that offer low latency performance. Personally I know that aptX low latency technology, can help to reduce audio delay.
Tudder
Posts: 7 Joined: Mon May 06, 2024 6:27 pm
Post by RichardT »
I would go wired.
I’ve found that routing the cable over one shoulder and down my back helped get it out of my way.
RichardT
Posts: 6033 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by adamburgess »
I've got some Senny RS120s I use occasionally. They're good old RF, so no latency.
As I rarely do any critical mixing, can't really comment on the (audio) frequency response, but they're nice and light on the neck while doing repetitive editing stuff etc…
adamburgess
Posts: 195 Joined: Sat Nov 03, 2018 12:18 pm
Post by Tomás Mulcahy »
RichardT wrote: Mon May 06, 2024 7:58 pm I would go wired.
Same here. Learned it years ago in studio work.
Tomás Mulcahy
And same here. I would only use wireless headphones for casual listening. They have no place in a studio.
