Ozone10 in Master Bus?
Post by JPOK1000 »
Hi all, I'm creating this post today as I'm in need of a little help as to whether or not it's a good idea to use Izotope Ozone10 in my master bus in FL or whether I should just use it for the final MIX when Mastering the entire mix. Also as Izotope has several EQ's on board do I need a separate EQ or Compressor?
JPOK1000
Posts: 4 Joined: Wed Feb 01, 2023 8:38 am
Re: Ozone10 in Master Bus?
Post by sonics »
You can use Ozone in either way. If your computer is powerful enough you can mix right into it with it on your master bus. Some like to finish a mix, and then concentrate solely on the mastering as a separate process.
Ozone includes all the EQ and compression you are likely to need; other tools are not a requirement at all, but many engineers will have their favourites which are not in Ozone.
Have you checked out the guides on the iZotope website?
sonics
Post by JPOK1000 »
My computer isnt a powerhouse, however, it's not too weak nether. I's running on 64GB of RAM, i7-11850HE 8 core. It seems to cope OK on most occasions, however, from time to time I notice a few pops & crackles on my mix whether this is down to using Ozone & too many other plugins I'm not sure.
Thanks for your help! :thumbup:
JPOK1000
JPOK1000 wrote: Fri May 10, 2024 11:00 pmIt seems to cope OK on most occasions, however, from time to time I notice a few pops & crackles on my mix ...
Check your buffer size, you might need to bump it up when projects get a bit more complex. :)
And there’s no point having it set small when simply mixing. Set it large and relax.
Post by JPOK1000 »
Thanks for the info chaps all helps. Would you say it's a bad thing to get carried away with & rely on the auto options in Ozone such as learn Threshold & Learn in the Exciter? Or would you say it's better practice to find the sound yourself?
JPOK1000
That depends on what you're trying to achieve.
If you're a musician first and foremost and just want to get your material out there, use the auto options and tweak until they sound good.
If you want to learn how to mix properly, then you'll need to settle in for the long haul and start from the basics.
There are all manner or short-cuts and automations you can pick up along the way, but unless you understand the basics you won't know when and how best to apply them. :)
JPOK1000 wrote: Sat May 11, 2024 7:30 pm Would you say it's a bad thing to get carried away with & rely on the auto options in Ozone such as learn Threshold & Learn in the Exciter?
When you go for a haircut, would you rather tell the hairdresser what you want, or say "give me the same as your previous client"?... ;)
Post by JPOK1000 »
Well to be honest I can't remember what I said to my barber the last time I had a haircut I've been as bald as a coot for the past twenty years. But yes I know what your saying it's for the best to manually find that sound your after. Trouble is that software is so damn good & full of so many options I find myself a little lost for choice sometimes. I think I'm just going to stick to using it in the master from now on.
JPOK1000
