Hugh's Digital Converter League table Update
For anyone who likes to track these things, I've just updated my league table of measured converters with my latest additions:
https://www.soundonsound.com/forum/view ... hp?t=79727
Re: Hugh's Digital Converter League table Update
Post by Zukan »
Thanks buddy.
Zukan
1-2-1 Tuition
Post by g18llo »
Hugh Robjohns wrote: Fri May 17, 2024 11:39 am For anyone who likes to track these things, I've just updated my league table of measured converters with my latest additions:
I wonder, is there any value in investing in one of these DACs, like the RME ADI-Pro II, and using that to mix on (I use headphones), rather than simply using my UAD Apollo Twin X? Anything going in, recording-wise, I don't use the Apollo, I'd use other pre-amps, the Apollo is just a "mixing device". Having read the list, and the associated reviews, one wonders if my best option is to get the RME, and a couple of nice pre-amps, and consign the UAD to A.N.Other marketplace.
g18llo
Posts: 48 Joined: Thu Dec 01, 2005 12:00 am
Bearing in mind the UAD is on the threshold of mastering-grade equipment anyway, I think I'd need a lot of spare cash in my pocket before I considered that as being the next upgrade option.
Post by g18llo »
Drew Stephenson wrote: Fri May 17, 2024 4:46 pm Bearing in mind the UAD is on the threshold of mastering-grade equipment anyway, I think I'd need a lot of spare cash in my pocket before I considered that as being the next upgrade option.
£700-£800 second-hand, that's less than an Apollo Quad X or a Twin X with additional plugins. In the grand scheme of professional audio interfaces, I'd say £700-£800 is relatively inexpensive given the new UFX III is closer to £2.5k.
g18llo
Post by tea for two »
g18llo wrote: Fri May 17, 2024 4:41 pm to mix on (I use headphones), rather than simply using my UAD Apollo Twin X? ...Apollo is just a "mixing device".
g18llo wrote: Fri May 17, 2024 4:53 pm In the grand scheme of professional audio interfaces, I'd say £700-£800 is relatively inexpensive given the new UFX III is closer to £2.5k.
Bearing in mind caveats points disclaimers as it were in Hugh's measurements lol.
If just for headphone out
then at 124dB A-weighted Headphone out measured under AES-17
an intriguing proposition is Audient id44mk2.
https://support.audient.com/hc/en-us/ar ... ifications
Its D-A line outs is 126dB A-weighted measured under AES-17 which would place it 2nd on Hugh's list of those interfaces currently available.
Given id44 mk2 price that's some going compared to Merging HAPI 126.3dB, Prism Sound Dream 124.5dB the top 2 D-A currently available in Hugh's list.
tea for two
Post by BWC »
I think what Drew's saying here is that, at any price, your money is probably better spent elsewhere in your setup.
BWC
Posts: 901 Joined: Thu Apr 29, 2021 9:12 am Location: FL, US
BWC
Indeed, it's not bad value, but you'd need to have a very well sorted room before you'll notice that kind of difference.
Drew Stephenson wrote: Fri May 17, 2024 4:46 pm Bearing in mind the UAD is on the threshold of mastering-grade equipment anyway...
More importantly, the Apollo in my list is a first-gen model from 2012, and it was exceptionally good back then.
I'd be amazed if the newer models didn’t perform even better, and probably well above my nominal mastering grade.
Post by g18llo »
BWC wrote: Sat May 18, 2024 2:56 pm I think what Drew's saying here is that, at any price, your money is probably better spent elsewhere in your setup.
I monitor on headphones, as discussed in the original post, so there's nowhere else in the setup to upgrade other than said headphones, NDH30s, or the Apollo Twin X.
g18llo
Post by g18llo »
tea for two wrote: Fri May 17, 2024 7:47 pm Its D-A line outs is 126dB A-weighted measured under AES-17 which would place it 2nd on Hugh's list of those interfaces currently available.
The ID range doesn't have the crosstalk feature found in more expensive convertors; that's a very, very useful function for me as I do 99% of my work on headphones, the Neumann NDH30's.
I've owned some of the interfaces on that list, and I've auditioned a few others on it too, and what I found to be the biggest difference (that I could notice) between them was the width of the stereo field, the more precise position in said field that and some were less "granular" in their overall sound. At the time of auditioning these I normally used an interface with 16 in/out, or thereabouts, as I was recording external sources, so some of those units weren't fiscally practical. Now, I'm just using 2 in/out, so the idea of using a higher grade of convertor seems more appealing.
I'll be able to report back on the RME ADI-2 Pro as I've just bought one, the anniversary version.
g18llo
g18llo wrote: Sat May 18, 2024 3:59 pm I'll be able to report back on the RME ADI-2 Pro as I've just bought one, the anniversary version.
:thumbup: Please let us know. :)
I thawd aboot enquiring whether Hugh would like to measure Audient iD4 mk2 I have as there are no AES-17 measurements on Audient's site for it.
Butt I did nae think it was worth Hugh's efrort. I would've covered return postage and Hugh could've kept it months.
tea for two
Post by AogL »
Hi Hugh
I believe you missed the Merging Anibus on the list.
What about the Lynx Aurora (n).
Best
AogL
Posts: 1 Joined: Sun Oct 21, 2012 12:00 am
I haven't had the Aurora(n) on my test bench. Sam reviewed that one.
I did review the original Anubis, but I didn't have suitable Ravenna hardware to access the digital I/O in a suitable format needed to perform AES17 measurements. Although I have no doubt it would have scored very highly.
AogL wrote: Wed Mar 19, 2025 5:39 pm Hi Hugh
Best
I reviewed the original Lynx Aurora for SOS way back in June 2006, and measured its D/A converter dynamic range as 115.5dBA
https://www.soundonsound.com/reviews/ly ... a-16-aes16
