Hi all,
Using Yamaha expression pedal through Yamaha MODX8 into Mainstage 3. The pedal controls volume for all patches except a couple of tremolo string patches. Is there a way of changing this?
It doesn’t seem to be affecting any other parameter on that patch
Thanks,
Daniel
Mainstage 3 - volume/expression pedal
- DanielBeach
Regular - Posts: 203 Joined: Sat Sep 14, 2002 12:00 am Location: Bromley
Daniel Beach
Logic Pro X 10.5, Yamaha MODX8 keys, NI Komplete 12, AmpleSound Guitars, various other software!
Re: Mainstage 3 - volume/expression pedal
More info - I've realised that it's only the Studio Strings instrument which doesn't respond to the volume/expression pedal. Does this need to be mapped somehow within MainStage for this instrument? Can't find a way to do that.
Thank you.
Thank you.
- DanielBeach
Daniel Beach
I can't help directly, as I don't use any of that stuff, but typically instrument patches have some sort of modulation system, and you will need to assign expression pedal to a volume control somewhere - I doubt this is anything to do with Mainstage itself.
