Eyam - nearly finished version
Members who have 100 or more posts under their belt can PM/email the Moderator Team requesting membership of this subforum. We will add you to the members group and you will then be free to post here to promote your own music, recording activities, releases and gigs, etc.
Strictly NO New Product gear/software posts are allowed in here.
Post by RichardT »
Here's a nearly finished version of a mockup of 'Eyam'. I'm happy with it apart from the tempo, which I might take down a notch. Interestingly, it sounds better at a higher tempo at high resolution, and not so good on Soundcloud. I've added more dynamics, phrasing, solo parts and developed some of the non-melody parts a little.
I hope you enjoy it! if you want to listen in hi-res, it's downloadable.
https://soundcloud.com/samplehound/12-e ... al_sharing
RichardT
Posts: 6032 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Re: Eyam - nearly finished version
Lovely. :clap:
Eyam (the place) holds a special place in my heart, so particularly poignant for me.
Post by amanise »
Completely agree. Lovely. The whole things amazing Richard.
:clap:
amanise
Posts: 5258 Joined: Thu Jan 26, 2023 1:45 pm
Adrian Manise
Faith in Absurdity :crazy:
A Hazelnut in every bite :wtf:
Very well done. it all fits together perfectly.
Post by OneWorld »
The Elf wrote: Tue Jun 04, 2024 7:45 pm Lovely. :clap:
My mum and dad, used to own the Lovers Leap Cafe !
OneWorld
Posts: 5958 Joined: Tue Apr 07, 2009 12:00 am
Post by OneWorld »
RichardT wrote: Tue Jun 04, 2024 7:35 pm Here's a nearly finished version of a mockup of 'Eyam'. I'm happy with it apart from the tempo, which I might take down a notch. Interestingly, it sounds better at a higher tempo at high resolution, and not so good on Soundcloud. I've added more dynamics, phrasing, solo parts and developed some of the non-melody parts a little.
Much admiration for this, well done. Do you ever submit your work to Radio 3?
OneWorld
Post by RichardT »
Thanks for the lovely comments!
I didn't know I could do that, One World, I'll look into it, thanks!
RichardT
Post by OneWorld »
RichardT wrote: Wed Jun 05, 2024 9:58 am Thanks for the lovely comments!
I have returned to listening to Radio 3, and they play such a wide range of music, it rwally has been a pleasant re-discovery. I suppose the way to get past the first portal is to look at programme websites and try and get the names of producers etc, I know there is the BBC Introducing option but that seems to be a somewhat narrow focus, wide ranging in the 'pop' world but beyond that I am not sure they consider that
OneWorld
OneWorld wrote: Wed Jun 05, 2024 1:07 pm I know there is the BBC Introducing option but that seems to be a somewhat narrow focus, wide ranging in the 'pop' world but beyond that I am not sure they consider that
Classical is an option in the genre category selection...
Post by OneWorld »
Drew Stephenson wrote: Wed Jun 05, 2024 1:43 pm
Great, if Bobbins is an option too then I am in with a chance
OneWorld
Post by tea for two »
2min27sec-3min57sec 5min01sec-6min17sec the uplifting tinged with melancholy.
Which MiDi controllers are you playing Rich to give movement to the Strings.
I've been on a Korg NanoKey2 for most of the stuff I do, I must admit it doesn't give movement to Strings.
Christian Henson on a vid was using Korg NanoKontrol2 to give movement to Strings. I never considered this before, considering relative affordability of NanoKontrol2.
tea for two
Post by RichardT »
tea for two wrote: Sun Jun 09, 2024 10:17 am 2min27sec-3min57sec 5min01sec-6min17sec the uplifting tinged with melancholy.
Hi T42 - I'm using Dorico to write the notation for the music. The playback software (Noteperformer) interprets the phrasing, articulations and dynamics in the score and converts them automatically to patch and parameter changes for the sample library (BBCSO core). So, luckily, I don't need to get involved in any keyswitching or controller automation. It's a relief I can tell you after doing that in Cubase for many years!
Unfortunately Noteperformer only works with Dorico, Finale and Sibelius.
What I'm hoping for is a 'Dorico' VST that I can run in a DAW so I can mix notated elements with recorded elements. So for example I could write a score for a string section in Dorico, point the Dorico VST at it in Cubase and have playback synced with the DAW tempo. But it's not here yet, if it ever comes.
RichardT
