The Elf wrote: ↑Tue Jun 11, 2024 5:39 pm
All this Volts, Amps and Watts stuff is completely baffling to me.
I'm trying to think of a way to say how Voltage and Current work together.
I'm unsure whether what I'm writing is clarifying or muddying, if muddying
please delete my post as it is a matter of safety.
A spin bowler bowling at 50mph, a fast bowler 90mph-95mph are let's suppose signify different Voltage levels.
The Current level is let's suppose whether a grape or a cricket ball is being bowled.
If the fast 90mph (high voltage) grape (low current) hits us it will hurt, butt a cricket ball (high current) hitting us at 90mph (high voltage) is going to do lot more damage even kill as has happened couple years earlier on an Australian cricket match.
If the spin 50mph (low voltage) cricket ball (high current) hits us then it will hurt but it won't kill.
If the spin 50mph (low voltage) grape (low current) hits us it won't hurt as much.
There's another important factor : how long in seconds the current is flowing, the longer in seconds depending where it's flowing in our body the more damage even lethal.
Wattage is the outcome of the spin or fast bowling (voltage) multiplied by grape or cricket ball (current).
Specs say Helix HX Stomp XL requires 27W as 9V x 3A.
So the plug Aled linked to which outputs 60W as 12V × 5A more than suffices.
I have a GAN power plug charger 20V x 3.25A = 65W to deliver thru a usbC port to my laptop usbC port.
Then there's such as Dell 150W laptop charger 19.5V x 7.7A.
These GAN power plugs and laptop charger are Class II devices shielded with plastic still they are not to be trifled with.
48V x 5A = 240W is the max that a usbC port power delivery can handle this would concern me if I had such a power plug charger.
I already unplug my 65W GAN plug when not in use.
A 100W = 20V x 5A GAN plug is the most I'd purrchase.
