My first post here, but a long time reader of SOS.
I’m having trouble interpreting REW results and what to do with them.
I tried my best to do things right but I’m not sure.So I would appreciate if somebody could help me.
I built some absorbers for the corners 40x40 from floor to ceiling. And some broadband panels for side and back walls 120 x 60 x 20 cm.Each of these walls has two of them.Ceiling has no treatment.
My room is not rectangular.I attached a drawing so you can have an idea of how it looks.
Attached also some amroc mode calculations for the modes of non-rectangular rooms.
My room dimensions are roughly 3.78 x 3.42 x 2.82 m although I have a dropped ceiling.True ceiling height is about 3.10 m.
Positioning:
I followed the 38% rule and my speakers are as close as possible to the front wall.They are separated by 1.42m but the distance of each one to my ears is about 1.10m.
Measurements:
Soundcard Calibrated.
Done with calibrated mic from sonarworks at 0 degrees.
I measured L and R independently, but I used different positions for each,approximately where each of my ears would be.For L and R together I measured in the midpoint between ears along the 38% line.
Thank you.
Thank you.
