Combining Control Room Outs of Two Identical Mixing Consoles for Direct Monitoring
Friends,
Back with another issue while setting up my studio.
Mine is a hybrid setup of audio interfaces / DAWs and analogue mixer(s), coupled with multi-computers as external synths.
With increased channel counts on my two audio interfaces, 2 ADAT Pre's and a 1212M also with an ADAT Pre, considering that I shall be using the 1212M in a 1616M configuration (breakout box). Plus there are two more PCs, one with a classic WR192X and the last one with Echo Mia 2496. This gives me an enormous number of channels, so I can basically plan such that drums take up a set of say 8 channels, and the rest configured suitably.
This of course puts me in a fix with regard to channel availability on my analogue mixer. Since I plan to mix on the analogue mixer first before any work inside the DAW, I bought an identical mixer so that I now have sufficient channels with the two mixers running in parallel (yes, parallel, and not daisy chained).
The point at which I am now stuck is monitoring the mix.
I read a review of this product on SOS by Hugh Robjohns as in the link below:
https://www.soundonsound.com/reviews/art-splitmix4
Not finding anything on the internet or in books about my unique setup, I decided to go for the ART SPLITMIX4, that would allow me to feed the monitor outs / control room outs of both mixers into the four mix inputs and take the mix out to feed my Crown XLi 800 power amp, which then connects to my legacy Tannoy Reveal monitors.
Can anyone tell me if this is a workable method to monitor?
- Jackie The Shepherd
Regular - Posts: 133 Joined: Fri Oct 05, 2007 12:00 am
Re: Combining Control Room Outs of Two Identical Mixing Consoles for Direct Monitoring
You seem determined to make life as difficult as possible for yourself...
Yeah I know but I still would like to have a nice answer if available
You say you've already decided to buy the SplitMix anyway, but yes... it should work.
Do you have anything at all running successfully yet? Rather than keep on adding gear to this theoretical system you would be wise to test each part of it as you go.
Posts: 29727 Joined: Sun Jul 05, 2015 12:00 am
I have already purchased the SplitMix4.
This is a repeating theme in your posts of engineering systems in the most hideously complex of ways and buying things without due diligence, only then to ask whether they are appropriate.....
Gotta say, you're doing it all the wrong way around and making life so difficult for yourself!
However, given that you need some way to mix together the outputs of two consoles you will clearly need some form of mixer.
...and the Splitmix is, indeed, some form of mixer.... a passive, unbalanced, stereo mixer.
So, given your earlier fanaticism over creating balanced direct output feeds, it seems rather odd to now that you would choose to create unbalanced monitoring outputs, while also incurring a significant loss of signal level...
But yes, it could potentially work... or you might find you have insufficient volume and ground loop issues.
Posts: 43708 Joined: Fri Jul 25, 2003 12:00 am
For the very best audio quality I would think one of the top grade monitor controllers would be the best solution.
Choose carefully though because in addition to the usually functions, source select, speaker select, mono, 'oop,' you need to mix two sources and not all controllers do that.
Hugh has reviewed a great many over the years I am sure one or two will meet your needs? 'Twere I, I would simply build a passive resistive mixer. The sources should all be at very low impedance ~100R and so such a device would not impact on frequency response and of course, resistors do not create distortion, at least not at non-lethal voltages!
Just a thought, must be a few SSL 'Sixes' on Ebay by now?
Hugh Robjohns wrote: ↑Tue Jul 02, 2024 10:37 am This is a repeating theme in your posts of engineering systems in the most hideously complex of ways and buying things without due diligence, only then to ask whether they are appropriate.....
Thanks. Though my power amp will accept balanced signals, the speakers are the old Tannoy Reveal - unbalanced.
I believe I should be able to compensate for the attenuation using the level controls on the SPLITMIX4.
ef37a wrote: ↑Tue Jul 02, 2024 10:48 am For the very best audio quality I would think one of the top grade monitor controllers would be the best solution.
Any recommended budget ones? I see something called Mackie Big Knob Passive Studio Monitor Controller which I shall study.
Last edited by Jackie The Shepherd on Tue Jul 02, 2024 12:49 pm, edited 1 time in total.
Assuming your Tannoy Reveals are passive (or you wouldn't need the power amp) they are neither balanced or unbalanced. Running a balanced connection to the amp would be the nearest you could get to a fully 'balanced' system. Putting the SplitMix into the system means that the connections between the mixers and the power amp are all unbalanced.
Since you've bought the SplitMix already why don't you try it and let us know if it works?
Forum Aficionado - Posts: 22920 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Sure.
And by the way, mixer control room outs are unbalanced.
Jackie The Shepherd wrote: ↑Tue Jul 02, 2024 12:34 pm Though my power amp will accept balanced signals, the speakers are the old Tannoy Reveal - unbalanced.
New or old, this is not relevant. Only powered speakers are likely to have a balanced input, since they are expecting a line feed. Passive speakers are expecting a +/- pair of wires from an amp - they will never be 'balanced'.
By going into the SplitMix before your amp you will be providing the amp with an unbalanced signal. You will have to take care with your wiring, since the SplitMix has stereo jack I/O - you don't want to get into the stereo/balanced confusion.
Jackie The Shepherd wrote: ↑Tue Jul 02, 2024 12:43 pmef37a wrote: ↑Tue Jul 02, 2024 10:48 am For the very best audio quality I would think one of the top grade monitor controllers would be the best solution.
No! I rarely condemn any piece of audio gear but the Mackie BK Passive is a flawed design. It puts a much too low a load on one 'leg' of a balanced source and does not preserve balanced through the device. I have one I have 'retired'. I might tear it apart one day and make it 'proper'!
If you need 'cheap' look at a small Mackie or Yamaha mixer.
Jackie The Shepherd wrote: ↑Tue Jul 02, 2024 12:34 pmI believe I should be able to compensate for the attenuation using the level controls on the SPLITMIX4.
Er.. no. The attenuation is DUE to the (passive) level controls in the SplitMix. Even with the controls at max you'll still get a 12dB loss through the box.
Hopefully, there'll be enough gain in your power amp to compensate.
And bear in mind that the connections to/from the SplitMix are stereo unbalanced on TRS connectors. So you will need splitter leads for both input and output, dual TS to TRS etc.
Jackie The Shepherd wrote: ↑Tue Jul 02, 2024 1:13 pm Sure.
Fair enough
Hugh Robjohns wrote: ↑Tue Jul 02, 2024 1:37 pmJackie The Shepherd wrote: ↑Tue Jul 02, 2024 12:34 pmI believe I should be able to compensate for the attenuation using the level controls on the SPLITMIX4.
Got it. Thanks
