Mixer Recommendations? - 16 Channel, Record to USB
Hi All,
So I'm looking for a recommendation for a new mixer for our upgraded podcast studio. We've been using the Rodecaster Pro 2 for 5 months in our "test" space, which has been great for what we needed it for, but we need something that's more intelligent, with more channels for a new larger space we're opening.
List of requirements;
- Needs to have multi-track record to USB function, ideally to an SSD which we'll use for the backup
- 16 channels will be fine
- Ideally supported by Riverside.fm as an external USB device, that compatible with Mac and Windows
- £2500 budget
- If their is also a smaller unit in the same range that does 8 channels, then would be good to use in studio 2 and keep everything branded the same
And that's pretty much it. We've tested the Allen and Heath QU16, and unfortunately have had a tonne of issues with it. Any recommendations?
- £2500 budget
- podshopstudios
New here - Posts: 8 Joined: Mon Jun 17, 2024 4:55 pm
Re: Mixer Recommendations? - 16 Channel, Record to USB
It doesn't I'm afraid, I don't think it multitrack records via USB Drive/SSD? Only stereo records.
- podshopstudios
- podshopstudios
Assuming you want physical faders a Behringer X32 Producer with an X-Live card will do what you need. Cost about £1600 per room (there isn't an 8 input alternative if you want the operating paradigm to be common to both).
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
The Soundcraft UI24R got so much right - might be worth a look? Way under budget too (though you’d need to factor in an iPad or such for control). It can multitrack record over USB and to a local USB drive at the same time for redundancy. Also has an onboard ‘automix’ facility for multiple speakers etc. that might be useful to you, though I’ve never used it.
I get a load of use out of mine, and it’s never let me down, but even though it’s a current product, I’m not sure what state Soundcraft and their support team are in these days, so that might be a concern.
Aled
Aled
- Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am
As far as I can see the Zoom L20 ticks all your boxes, and there's the smaller L12 available for the second studio.
- Sam Inglis
Moderator - Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
podshopstudios wrote: ↑Mon Jul 08, 2024 11:00 am
It doesn't I'm afraid, I believe it only records stereo to USB drive?
Sorry, you are right. Have you looked at A&H CQ series mixers?
Turn the knobs 'til the music moves ya.
podshopstudios wrote: ↑Mon Jul 08, 2024 10:23 am We've tested the Allen and Heath QU16, and unfortunately have had a tonne of issues with it.
I’ve become quite the A&H fan in recent years and was going to suggest one or other of the Qu range.
Can you elaborate on the issues encountered?
- shufflebeat
What I really like about the Zoom LiveTraks is their ability to record to local SD card *and* provide USB output to a DAW simultaneously.
FWIW the X32/X-Live rig does likewise.
(Really wish the XR18 did...)
I've been using the CQ 20B with great results, it's exceptionally good sounding and the SD card recording is flawless.
- resistorman
Zoom and Behringer are too budget, I'm after something with more function.
I've kind of been put off from A&H now after the issues faced with the QU16 (multi-tracks recordings are corrupted, hums where they shouldn't be, not compatible as a USB device input with Chrome or Edge).
- podshopstudios
podshopstudios wrote: ↑Tue Jul 09, 2024 4:51 pm Zoom and Behringer are too budget, I'm after something with more function.
What functions do you need?
How about the Midas M32, it has better mic preamps and faders than the Berry but the OS is identical. The M32R Live is still well within budget if your £2.5k is for one room.
I don't know the Zoom but if it's lack of functionality/features rather than build quality/sound quality that puts you off the Berry/Midas I fear you will struggle to find anything that does more for your budget.
As The Elf says, decide what functions you want/need and there will probably be someone who can confirm/deny if a specific desk can do those things.
While it's true that the DM3 can't directly record multitrack to an SD card, given your budget, you could just hook it up to a low-cost laptop and have that handle the recording. (after all the non-Dante DM3S is £1500 so you still have a grand left). Just set up a simple project in Reaper and you're good to go.
It has the advantage of being extremely compact, (it's about the footprint of a 15 inch laptop), which most of the other mixers definitely aren't, and the latest v2.0 firmware gives you the option of splitting the 18:18 audio interface into four logical USB devices, three of which are stereo 2:2 devices, and one handles the remaining 12:12. This is obviously aimed directly at podcasting, where you could stream audio into the mixer from multiple apps on a PC simultaneously or route audio out to different USB devices without worrying about conflicts caused by trying to use a single logical device.
It's also a very ergonomic little device, and although we don't yet have Dugan automixing, Yamaha reps have implied that it's definitely coming in a future firmware release. Finally of course it's made by Yamaha and designed for demanding environments. Mine came with a 2 year manufacturer's warranty, which is reassuring, and it's been absolutely glitch-free so far.
Another advantage of hooking it up to a laptop is that you can then use a StreamDeck to add functions - all mixer functionality is exposed over OSC for which there is now a StreamDeck plugin. Also of course it supports an iPad - but disappointingly not an Android tablet - for remote control of the desk.
