hello all
ive just got an ik axe i/o one
and i was hoping to use it for recording guitars using reaper
im also using my focusrite scarlett 2/4
and was hoping to switch between the two in reaper
but im getting all sorts of issues ,mouse freeze ect when i change between the two
im also using sonarworks 4 which seems to be trying to switch the samplerate
from 44 to 48khz
does anyone know of a way to make them switchable without it causing issues
im only wanting to use either one at the same time not both
Using 2 interfaces seperately in Reaper
Re: using 2 interfaces seperately in reaper
In my experience, trying to switch between interfaces can be an issue. For me, for example, any ASIO settings get nuked so you have to go back in and change the buffer size and possibly sample rate.
Projects saved using one interface and loaded with another one active also seem to cause confusion at times.
I *think* ASIO4ALL is supposed to be able to accommodate multiple interfaces though I haven't tried this. It's annoying that Apple seem to have figured out how to manage multiple interfaces (and treat them as a composite interface) but Windows can't do this properly. Windows audio is certainly a lot less fragile than it used to be, and although I'm not sure this is specifically a Windows 11 enhancement, I note that Reaper now when it complains if I forgot to turn my audio interface on when I start up Reaper, it'll recover if I do and acknowledge the error - which is encouraging.
Don't know if anyone has any clever solutions here, I certainly get how annoying it is trying to just switch interfaces without everything going weird.
I have no problems switching between a Zoom U-44 and an RME Digiface USB in Reaper. I currently have them both hooked up simultaneously and swap between them as needed. I'll sometimes add a Zoom U-24 into the mix as well. Newer versions of Reaper can remember how many channels you were using with each interface and set the correct number of channels automatically on switchover. Buffer size settings stay constant for each interface so I'll typically leave the Zoom on a fairly large buffer size while the better RME drivers allow me to use a smaller buffer size. I have the sample rate controlled by the project.
However, you need to set each project to use the correct channels on each interface. This won't be a problem if you are only using 2 channel interfaces but, with the RME, some projects have the master output on on channels 17 and 18, some on 1 and 2 and some on 33 and 34 - depending on what I'm doing.
I have encountered badly written drivers/firmware (I'm looking at you Tascam) which are very fussy about sample rates. The Zoom is only fussy about sample rates when it is being clocked by an external digital device. Could you put up some screenshots somewhere of your Reaper audio device settings and possibly also the ASIO control panel for each device?
Re: Using 2 interfaces seperately in Reaper
https://www.soundonsound.com/forum/view ... hp?t=75253
This is a link to a useful guide to attaching images to forum posts, created by one of the forum regulars.
The SOS fora don't host images so you have to host them on 3rd party sites like Imagur etc. Once you've done that, the link above will guide you through.
Andy
Andy
The easiest way to switch between 2 interfaces in Windows is to use Portable Install (an installation option) to install 2 separate installs of Reaper, one for each interface. It helps to create 2 icons, one for each, and edit the icon text to indicate which interface it uses.
- Philbo King
Regular - Posts: 383 Joined: Thu Oct 11, 2018 10:07 pm
No, you use instance of Reaper only for one interface. Reaper will not be aware the other interface or copy of Reaper exists.
Note that you *might* not be able to use both Reapers at once.
- Philbo King
