Multi USB-C adapter for Mac? Is it even possible?
Some of my Macs have 4 usb-c ports, others only 2 usb-c ports. I'd love a multi usb-c port adapter to increase access to the computer but not being savvy about these things I wonder if they exist. What I mean is could. the computer handle multi usb-c input? Much obliged for any replies.
- Howdy Doody Time
Frequent Poster - Posts: 829 Joined: Sun Jan 18, 2009 12:00 am Location: Huai Yai, Chon Buri, Siam
The only excuse we have for making music in the first place is to make it differently..vis-a-vis our own difference (Glenn Gould)
Re: multi usb-c adapter for Mac? Is it even possible?
Well, it’s a bus, and the C type connector is only that. All my stuff works exactly like it did through “B” connectors on my old iMac now I use a new iMac and “C” connectors.
That’s my technical limit reached. I expect Hugh or another more technical expert will be on the next bus …
Indeed so. From the beginning USB has been based around the idea of hubs and there are lots of them widely available. The other thing to be aware of is that the USB ports on your computer provide power that can be used to power things like audio interfaces. The hub Tacitus has linked to is unpowered, that is it shares the power from the computer port across its four ports so if you're looking to power kit through it it might be chancy. In that case you'd probably be better with a powered hub like this:
https://www.amazon.co.uk/Powered-Extens ... B0BWXHJQ43
- ConcertinaChap
Jedi Poster -
Posts: 15235 Joined: Wed Jul 20, 2005 12:00 am
Making music: Eagle Alley
Depending on the audio interface, since USB 3 onwards it can deliver more current than USB 2 (up to 3A in the case of USB 3.2), so you might well be able to use an unpowered hub. I have a four way hub that I use on both my M3 Macbook Pro and M1 Macbook Air; currently running a Behringer UMC404, a Presonus Atom and a NI Kontrol S88 mk3 with no issues. (There's also a Presonus ioStation on it too, but that's got its own power supply).
- Rich Hanson
Frequent Poster - Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Re: Multi USB-C adapter for Mac? Is it even possible?
Putting this up before Drew gets in:
- ConcertinaChap
Jedi Poster -
I personally don’t risk an unpowered hub when doing anything live. My hub takes one USB-C port, and then the hub passes the power back to the mac.
I put the external hard drive into the second USB-C to make sure there’ll be no connection issues, and then midi keyboards, sound card etc go into the hub
- DanielBeach
Regular - Posts: 203 Joined: Sat Sep 14, 2002 12:00 am Location: Bromley
Daniel Beach
Logic Pro X 10.5, Yamaha MODX8 keys, NI Komplete 12, AmpleSound Guitars, various other software!
ConcertinaChap wrote: ↑Thu Jul 25, 2024 10:54 am Indeed so. From the beginning USB has been based around the idea of hubs and there are lots of them widely available. The other thing to be aware of is that the USB ports on your computer provide power that can be used to power things like audio interfaces. The hub Tacitus has linked to is unpowered, that is it shares the power from the computer port across its four ports so if you're looking to power kit through it it might be chancy. In that case you'd probably be better with a powered hub like this:
No. What I want is multiple usb-c hub connecting to the Mac usb-c port thereby allowing for lots of new fangled usb-c things to be connected all at once. I have MBP 1 and 2 Macs. which is why I don't know if its even possible
- Howdy Doody Time
So you want USB-C in and out?
Exactly like a normal USB hub, which increases the number of usb inputs, except that it would be a USB-C hub increasing the number of USB-C inputs. I really don't know how else to describe what I'm looking for.
- Howdy Doody Time
So something like this: https://www.amazon.co.uk/UGREEN-Aluminu ... d_source=1
But ideally a powered one I guess.
EDIT - like this: https://www.amazon.co.uk/Selore-S-Globa ... hdGY&psc=1
Also whichever way you go things like these always come in handy:
https://www.amazon.co.uk/UGREEN-Adapter ... B0CZDQ8RMX
Or in the other direction:
https://www.amazon.co.uk/Adapter-Anker- ... B08HZ6PS61
- ConcertinaChap
Jedi Poster -
Absolutely marvellous Thanks all!
- Howdy Doody Time
Just seen Anker have released their 'Prime Series' which feature some handy looking hubs/chargers.
https://www.anker.com/uk/products/a2683 ... -ports-gan
This one looks about right for me at least. Handy with a couple of USB-A and then really 3 USB-C I suppose rather than 4 as 1 to attach to the computer I guess. I'm just going through the specs now but they've just released a bunch of new USB-C products so hopefully one that'll work for you.
Did you end up getting a particular one?
I've just been reading some positive reports of Startech USB hubs for audio related uses. Seems like they're proper IT Professional jobbies.
https://www.startech.com/en-gb/usb-hubs/usb-c-hubs
I've bought a number of Startech cabes over the years, Thunderbolt and video mostly, and I have a high opinion of them so I'd have no problem buying a Startech hub if it had the facilities I wanted.
- ConcertinaChap
Jedi Poster -
