BigRedX wrote: ↑Wed Aug 14, 2024 7:41 am
Muzines, have you been able to get any more information on this problem?
So, I've only been able to investigate when the drop out happens. For a week after the initial event, I had zero problems, Scarlett and Stream Deck were behaving as expected - until exactly a week later, watching the same YouTube stream, I got the drop out again - so it was exactly the same scenario as when I first experienced the drop out.
While the audio was gone, I loaded another app to playback audio and found the audio played through the interface fine - so it wasn't that the Focusrite driver had stopped, or the hardware gone away, or the system audio had gone - the Scarlett was still working fine.
As I was running Safari/YouTube through plugins via Audio Hijack to compress the YouTube stream, the drop out had happened somewhere between YouTube, the audio output of Safari, and the hijacking of Audio Hijack, as it was Safari that stopped producing audio and Audio Hijack was getting no audio input - and as yet, it hasn't happened again, so I don't know whether any of this is actually related to the Stream Deck, or whether it was just a co-incidence it happened just after I got mine. And if it *is* somehow caused by the Stream Deck, I don't know whether the issue is interrupting audio from a particular app, or the Audio Hijack process, or some other weird thing, or whether it happens when the Stream Deck is not connected, or on another USB bus etc - all things I would try if I could replicate the issue enough to test these things.
It hasn't happened since, so I'm none the wiser, really.
BigRedX wrote: ↑Wed Aug 14, 2024 7:41 amDo the Focusrite interfaces use a driver in order to work?
No, they are class compliant devices.
