hello all
ive set up both of my soundcards (axe i/o one and a focusrite scarlett 2in4)
to use reaper(the focusrite) and a second portable install of reaper (for the axe i/o )
and the setup now works well following some previous forum advice
what i need now is some sort of midi switch so i can send the midi from my keyboard and pedalboard between the 2 cards as im using them
i would need to be able to switch between the keyboard and the pedalboard
and also send wichever midi device is selected
between the 2 soundcards
as anyone got advice on how to do this as cheaply as possible ?
MIDI switcher box
Re: MIDI switcher box
Does the keyboard or pedalboard have MIDI thru? If so, maybe you could use that to combine them, then run that into a MIDI splitter like the CME Thru5.
(Their U6MIDIPro might also be an option; haven't studied the details but it looks like you can use a graphical interface to assign inputs to multiple outputs. It's more flexible and only slightly more expensive.)
hello big
thanks for the reply
the footpedal is a beringher FCB1010
had it does have midi out/thru
does this mean i can plug my keyboard into it ?
ive looked at the first box u mentioned and it looks like itll do the job
Does the midi need to go through the audio interface or could you use a separate midi interface?
There are much cheaper MIDI splitters around. I'm on my phone right now but a quick search suggested this:
https://www.amazon.co.uk/CME-MIDI-Thru5 ... B0B9ZJG69B
Posts: 9976 Joined: Wed Sep 01, 2004 12:00 am
well ive got my keyboard midi now going thru the fcb11010
and ive bought one of the cm boxes
thats gonna take care of all i needed to do
thank you all for your advice and suggestions
may the force be with you all
I thought I'd messed up for a minute, thinking that MIDI Thru included data from the device as well as the input...but it doesn't usually. But it sounds like the FCB1010 can, so maybe I got away with it?
https://forums.musicplayer.com/topic/15 ... r-fcb1010/
