zenguitar wrote: ↑Wed Sep 25, 2024 2:15 am
If it's not loud enough... you turn up the gain. So what is preventing you from doing that?
And mic placement is perfectly straightforward. You manage it with no problem for home recording of vocals and acoustic guitar. So what is it about Discord that makes you want to take a different approach, when you have a proven process that works for you
Hi Andy, I appreciate you taking the time to respond to my question
Every reaction is really helping me figuring out on how to optimize my setup!
Now a little bit on why mic placement differs for recording and for talking over Discord: for recording I place the mic table stand right in the middle of the desk, so that I can comfortably sing or play guitar. The PC keyboard and the PC monitor are right behind the mic. That doesn’t bother me while tracking (I am using Cubase iC Pro to operate the transport in this case). I am getting good signal levels this way and gain-wise there is ample headroom left.
On Discord, I want to be able to see the PC screen better and have access to keyboard and mouse. Consequently the mic has to move. I am moving it to the right side, towards my audio interface. That is also where my mouse is. So the mic then sit probably 45 cm away from my mouth at a ca 45 degree angle. That is the zone in which I can run out of gain, depending on how far exactly I have placed the mic and how closely I am sitting at the desk, which also changes slightly during longer Discord sessions.
A headset with mic definitely helps, but as my space is very limited I would like to avoid a second headset, just to reduce „clutter“.
I can also use an insert on UAD console for a little extra gain e.g., a compressor. But depending on if I have a Cubase project open that already uses the DSP processor of my interface (Apollo Solo, which doesn’t give me a lot of processing power) this isn’t always working.
I hope this is making the setup a little clearer
I know a photo of my desk would make it easier for everyone to picture it, but I am currently enjoying vacation, so can’t share that now
Again, thank you so much for your comments!
