Pedals, picked out of current collection, will be:
Boss BE-5 (compression, overdrive, gate), then Send to
Tomsline Bluesy
Behringer Graphic EQ
Landlord Spinning Room (mult-mod)
Donner Dynamic Wah
Donner Yellow Fall (analogue style delay)
Return to Boss BE-5 (DDL, Chorus) then a possible
Donner Tutti Chorus on the dry output - to be determined by ear whether it adds anything to the Boss Chorus...
Finally stereo I/O to Boss RV-6 reverb
This fits comfortably in about 500 x 300.
Probably going to power it via a (Thomann) Harley Benton ISO-1 Pro - having noted previous SOS comments about the importance of good PSUs, I think this will be ‘good enough’ for non-gigging use.
The question really is about the board itself, and fixing the pedals in place. I can chop up and screw together bits of wood (ply, edging) fairly competently, but wonder if folks think that there are pedalboard bases out there that make it not worth bothering?
When it comes to fixing pedal in place, Velcro is the norm but I am not mad about the one-way trip (or messy removal) this entails.
These look fairly sensible:
https://www.thomann.de/gb/harley_benton_mounties.htm. Unscrew the pedal base, slip the bands over the screw holes, put back together then screw down to the board. But is there any other simple/ DIY system like this?
I don’t need gig-worthy reliability, just something that stays in place and looks reasonably neat.
Thanks for you thoughts
