Recording changes to hardware synths in Cubase
Post by The Paul meister »
Hi everyone,
Is it possible to record changes to hardware synths via midi in Cubase Elements 13?
Or do you need the full version of Cubase?
Thanks, Paul
The Paul meister
Posts: 529 Joined: Tue Feb 28, 2006 12:00 am
Re: Recording changes to hardware synths in Cubase
Most synths, if they *can* transmit control changes, will output MIDI CCs or Sys-Ex messages. I can't imagine Steinberg would filter out the CCs for MIDI tracks in different versions of Cubase. Sys-Ex may be different story, but I doubt it.
Posts: 21435 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by alexis »
Hi The Paul Meister!
Should be able to get a definitive answer here:
https://forums.steinberg.net/c/cubase/6
alexis
Posts: 5284 Joined: Fri Jan 10, 2003 12:00 am Location: Hampton Roads, Virginia, USA
Thanks Alexis,
Will have a look later
The Paul meister
I couldn't anything in the forums to give a definitive answer either way, and the Cubase version comparison chart shows nothing of any value to this question.
...just to save you some time looking.
Ok, thanks The Elf
The Paul meister
I just contacted Steinberg support about this.
The Paul meister
Post by alexis »
The Elf wrote: Mon Nov 04, 2024 2:46 pm I couldn't anything in the forums to give a definitive answer either way, and the Cubase version comparison chart shows nothing of any value to this question.
I'd post a question to the Cubase forum, likely get a good quick answer (probably from Martin!).
alexis
