How Do They [Kraftwerk] Make This Sound So Good?
How do they make this recording sound so good?
Specifically, I'm interested in the sticky, palpable attack tone that is present on the kick, the bass and the staccato synths. This sound seems to permeate the whole song. Although not subtle, it is not overdone either. To my ear it sounds highly attractive and seductive in a sort of technological way that perfectly suits the ethos of this seminal band.
https://www.youtube.com/watch?v=SaoBbCC66I4
Is it an eq boost, perhaps in 1kHz. Or some sort of compression or transient treatment, maybe combined with eq?
For me it's certainly a unique sound, I have not heard it on other synth-based records.
Or am I over-analysing it? It it just a case of the whole being more than the sum of its parts, due to a consistent quality in the sound design, arrangement, musicianship, engineering and production?
I wish my songs sounded this good!
- Jathon Delsy
Regular -
Posts: 205 Joined: Fri Dec 05, 2014 12:00 am
Re: How Do They Make This Sound So Good?
Only had a quick listen, and it's not something I'm familiar with, but my initial take is to focus on the arrangement. There's no fat in there. Things come in and out but they do their job then disappear, nothing's fighting with anything else for bandwidth.
What Drew said, plus, I find getting a clean well defined "clear" sound involves taking things away, the less there is in the signal chain, the better. A lot of Kraftwerk records have this sound, the philosophy is to make it as artificial and "technicolour" sounding as possible, which equates to clean, and direct, they are electronic instruments after all.
My first thought is that you need to forget about processing - get the sound at source and preserve it rather than processing a less than perfect sound.
They haven't made it sound good - it was good to start with.
James Perrett wrote: ↑Wed Nov 06, 2024 11:16 am My first thought is that you need to forget about processing - get the sound at source and preserve it rather than processing a less than perfect sound.
That’s right James, I've always tried to get my synth sounds right on the instrument, rarely using external processing, or EQ.
Thin Kick :
For this clear mix imo is the thin Kick.
If the Kick was deep heevee stacked Kicks it would drown out the other Synth sounds which would make it a muddy mix.
Robotic voice :
Pitched where it would sit well with the other Synth sounds phrases.
If it was a Barry White voice it would probably become a muddy mix.
If it was a Falsetto Barry Gibb voice it would clash with the higher Synth sounds phrases.
Arrangement and choice of sounds :
The choice of Synth sounds phrases are sculpted played where they won't clash with one another, where they might clash then one Synth sound phrase drops out.
Mix :
Is not shoved in our face.
There's things in the background.
Listening on AKG K245 for bottom. Shure Srh1440 for mids highs. On this 2009 remaster the highs are trifle too high for me, I would taken the highs down a notch.
Ps. To me it sounds as We are F*ing Roboter on this 2009 remaster. Lol.
Early 80s first heard it no idea what was being sung who song was by.
Early 90s a chum gave Man Machine album as a present as soon as I heard We are the Robots .... eureka.
Robotic voice :
Mix :
- tea for two
The mix of Expo 2000 on 12 inch single is earth shattering, potentially speaker destroying. The bass is so powerful, and the voices are an inch from your face, you can almost "see" into that vocoder.
James Perrett wrote: ↑Wed Nov 06, 2024 11:16 am They haven't made it sound good - it was good to start with.
Precisely! All about the song and arrangement structure - love the Question (vocoder) and Answer (synth motif) style halfway through.
It's not for no good reason that Kratfwerk's music influenced so many electronic musicians. [Boring as f**k to watch live, though - saw them at Newcastle City Hall when they did the 'shop dummy stage presence' period. Went to the bar and sunk a Newcie Brown. Could still hear the music and it sounded better to my ears, like having a very loud Jukebox in the corner.]
The group are a bit more animated in this 1976 Paris gig video from YouTube:
https://youtu.be/rEGSnE-5ypg
- Forum Admin
Posts: 4767 Joined: Mon Jul 21, 2003 11:00 pm
Saw 1/2 KW first thyme 2004 Brixton Academy : just 2 original members + 2 newbees. I was too close to the stage had to step back because the bass was altering my heartbeat.
Later became 1/4 KW : 1 original member + 3 newbees.
For me this is because didn't need to have sublime compositional improvisational ability of Vangelis, didn't need to have solos intricate sequencing of Tangerine Dream Klaus Schulze, didn't need to have sound design layering interweaving synthesis inventiveness of JmJ.
Main thing needed was sparse Funk Beats sparse Funk Bass simplified electronified which is what KW did copied, with bits n bobs of other stuff chucked in.
Karl Bartos was the only KW member to openly say enormous influence James Brown and Funk upon KW.
Forum Admin wrote: ↑Wed Nov 06, 2024 12:58 pm It's not for no good reason that Kratfwerk's music influenced so many electronic musicians.
- tea for two
Re: How Do They [Kraftwerk] Make This Sound So Good?
Thanks for the usual brilliant replies.
For me this songs is a masterclass in music production. As I suspected, much of its power comes from the incisive, sculptured economy of its composition and arrangement.
Yes, I can hear the James Brown influence. Also I hear a classic Europop influence, that is using simple, standard changes and structures and snappy beats to create a catchy, poppy song.
But I believe that prior to all this is the band's clear, precise artistic vision. You've got to know where you're going to get anywhere.
I can hear their seminal influence in many places, but for me no other group gets such a clearly defined sound, both sonically and artistically.
- Jathon Delsy
Regular -
Jathon Delsy wrote: ↑Tue Nov 05, 2024 5:18 pmSpecifically, I'm interested in the sticky, palpable attack tone that is present on the kick, the bass and the staccato synths.
They just added a digital click to the beginning of the sound, esp. the kick.
Back then they had to programme it in on the sequencer - today you can just add it in your DAW.
- The Red Bladder
Frequent Poster - Posts: 3904 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
The Red Bladder wrote: ↑Thu Nov 07, 2024 12:54 pmJathon Delsy wrote: ↑Tue Nov 05, 2024 5:18 pmSpecifically, I'm interested in the sticky, palpable attack tone that is present on the kick, the bass and the staccato synths.
Wow! Thanks The Red Bladder. That is precisely the answer I was looking for! Bravo.
Any suggestiens as to what to use, or where to get, a suitable click tone. I suppose the clicks used with many metronomes will work.
- Jathon Delsy
Regular -
Jathon Delsy wrote: ↑Thu Nov 07, 2024 1:42 pmAny suggestiens as to what to use, or where to get, a suitable click tone. I suppose the clicks used with many metronomes will work.
Any unwanted electronic click will do - experiment! I use the clockwork metronome for adding oompf to handclaps and I put a nasty click in front of the kick sample from a dDrum head. Try smacking a wooden baton on a table or the floor.
There must be a million ways to get a funky kick drum. Gun fire. Try slapping a very fat person on the arse! I bet that makes one hell of a good noise!
- The Red Bladder
Jathon Delsy wrote: ↑Thu Nov 07, 2024 1:42 pmThe Red Bladder wrote: ↑Thu Nov 07, 2024 12:54 pm They just added a digital click to the beginning of the sound, esp. the kick.
I don't think it is a digital click - I'd say they layered a short synth blip over the longer tone. You should be able to program something appropriate on any analogue synth or VST emulation (if you want to know how then look at the Juno 6 manual for inspiration as they have something similar there, at the top of page 27 in the sample sounds section).
