Watkins Rapier 33
Watkins Rapier 33
I am renovating a Watkins Rapier 33.
The electronics look as though someone has already been there!
Is anyone aware of a schematic? I have has a look on the internet but not found anything.
The one I have has three “normal” pots not two pots and a rotary switch.
Re: Watkins Rapier 33
I'm guessing you want an authentic reproduction of the original circuit? Calling Zen and Wonky?
Edit :- I don;t think this is quite the same as yours but might be useful https://www.facebook.com/photo.php?fbid ... 5879663038
There are several different control arrangements, what switches does your have in addition to the three pots?
* If the aim is to make a playable guitar then details of the available controls and pics of the back of the scratch plate showing the existing wiring (such as is left at least) would be a starting point and you can probably choose from couple of different arrangements.
The Watkins Rapier pre-dates my guitar life by a decade or so.
Fortunately
If I were to be renovating a Watkins my starting point would be to approach a specialist vintage dealer and ask them for a recommendation of a recognised expert.
Andy
Fortunately
Andy
Thanks for that.
Mine has three normal pots but no rotary switch.
There is a two way switch with four lugs.I think this was to have the bridge and neck pick ups together or just bridge or neck,not sure which!
There is also a switch which apparently was made for Pifco hairdryers!
It has a red switch and a black switch.
I think one switch was to engage the middle pick up and the other for a an overall bass cut.
I think one pot is master volume,one master tone and the last one middle pick up volume.
That sounds approximately similar to something I read on the Fretboard forum though they didn't mention the Pifco switch.
And a couple of images here that might help
https://reverb.com/uk/item/85174304-wat ... ite-silver
I'm pretty certain that we had a hairdryer in the 60s with exactly that switch on it!
This thread brings back memories from my schooldays - I'd patiently built my own electric guitar with help from a schoolteacher and the facilities of the woodworking classroom, and the parts cost me £17.
Then a schoolfriend told me he'd have sold me his Watkins Rapier 44 (complete with FOUR pickups) for £15
Posts: 22581 Joined: Wed Jan 13, 2010 8:44 am
Needs a new scratchplate!
Also needs refinishing it has been sanded down to a natural colour it should be red!
The neck has about 15 thousands of relief with no tension.There is no truss rod.
Could well need a refret after taking out some of the neck relief.
Should keep me out of trouble in the dark winter months!
