James Perrett wrote: ↑Thu Nov 21, 2024 10:28 pm
I probably phrased it badly. What I meant is that you are boosting the sounds that you think are too quiet. Instead, try cutting the sounds that are too loud because these sounds are masking the sounds that you want to hear.
When you go to the studio you should also take along some commercial recordings that sound good to you on your hifi so that you have a known reference to compare things to. I'll bet that commercial recordings don't have as much going on below 100Hz as your recording does.
Haha, you arrived to the source of the problem even if you did not know the full story. I cannot use a reference here. Almost all records I have from this genre suffer from the problem that I am describing in this case. But I did not want to mention that because it deserves a separate topic, I wanted to talk about that aspect later as it would be too much for 1 single topic. That's why I suggest to focus on this recording only. We can compare it to other styles, I have reference from those for my system, the experiences I have listening to those were concluded in this recent project.
I can show you something however that is my genre, and I used that as a direct inspiration for this recent project:
https://youtu.be/VDdKk6-mSuA?si=IV7dRMbkOEoSAvEX&t=106
It suffers from the same symptoms like my mix. Good on quality speakers, bad on low end I did not even notice it so far, just now that I have problems with my project. I love the mix there, the lead guitar is a bit low, but apart from that I love how the bass is mixed. I tried to replicate this on my mix, because I knew it will sound so good on the HiFi.
About boosting certain sounds: depends on which part of the spectrum you mean. Yes, I boosted certain stuff that obviously could be flagged as better to mix down, but all I did was just to listen on the built in laptop speakers, and adjust this until I am satisfied. And that curve on the photo is the result. This is how I find it sounds good on such low end stuff. Some adjustments also go against what I expected, but this is how I hear it sounds good.
