Hi everyone! Hope someone could help me.
I’ve got a problem with my id24. It produces some crackling sound in the low frequencies only from the headphones. I’ve tried with different guitar and cables but nothing change. I’ve done the return with amazon and have another one but the problems persist. I’m really discourage.
Is there anyone with same issue?
Thank
Here's a link from soundcloud
https://soundcloud.com/giacomo-carveni- ... al_sharing
Audient id24 issues
Re: Audient id24 issues
I couldn't hear any crackling on that so it is probably a problem on playback rather than recording. Have you tried increasing the buffer size and all the standard performance adjustments?
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am
There is possibly a very slight click on the first note but I can't hear anything wrong on the rest of the notes. This is using Sennheiser HD600s and HD25s.
I hear it now - I was listening for distortion on the transients rather than on the sustain part. That sounds a bit like clocking to me. Can you describe your complete setup with makes, model numbers and the exact type of connectors used? Also what sample rate you are using and exactly what software you are using? The more information the better...
Buffer size? And are you using a compressor on the signal coming in?
Check what clock source you are using in the Audient control panel.
