Laptop PSUs - I just don't get it!
Recently I purchased an LG Gram laptop. It came with a 90W 'Fast Charger' PSU (connects via USB-C).
Today I plugged in a 130W Dell PSU as I worked, and the battery has run down, since the laptop says it is not getting enough power from the PSU. :crazy:
I don't get it!
Trying to find an additional PSU for this laptop is proving impossible. I'm seeing so many specs and numbers my head is spinning! None of the options I've seen mention 'fast charger'.
In short, what do I need to buy to have a second PSU for this laptop that will not end up with the battery draining?
Re: Laptop PSUs - I just don't get it!
Post by DGL. »
It's interesting that it doesn't like it, my 2017 Lenovo can charge from either the proprietary Lenovo supply/connector or USB-C, Windows does complain that it is not charging and to use the correct PSU but it's actually lying and charges just fine from either a generic Delta 65W USB-C charger (identical to one shipped with a MSI laptop) or one from a Nintendo Switch.
DGL.
Posts: 2320 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
Post by Matt Houghton »
I can't see from that pic due to the resolution, but is there perchance a part number written upon it? (Is that what is near P/N towards the bottom?) If you can't find the spec you need on the device itself, I'd stick that along with LG Gram into Google and see what it throws up. (I'm assuming that QR code doesn't take you anywhere useful?)
Matt Houghton
Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Post by tea for two »
In time honoured SoS fashion we require more info : such a rookie. :lol:
The Elf wrote: Sat Dec 14, 2024 5:23 pm Recently I purchased an LG Gram laptop. It came with a 90W 'Fast Charger' PSU (connects via USB-C).
What's the exact model for LG charger and Dell charger.
The LG charger looks like LP90DGC20H-WW outputs 20V 4.5A max for 90W max.
The Dell charger should be able to output this from a single usbC cable. The V, A, and W numbers on the Dell charger will tell us.
If the Dell charger can't output 20V 4.5A 90W that could be the issue.
When I had a similar issue with my Asus laptop charging via usbC port, it was the usbC cable that couldn't deliver the required Wattage. I had to get a usbC Iniu 100W rated usbC charging cable that did the trick. Before this I had to get a usbC charger that outputted the required V, A,W for my Asus.
tea for two
Matt Houghton wrote: Sat Dec 14, 2024 6:27 pm I can't see from that pic due to the resolution, but is there perchance a part number written upon it? (Is that what is near P/N towards the bottom?) If you can't find the spec you need on the device itself, I'd stick that along with LG Gram into Google and see what it throws up. (I'm assuming that QR code doesn't take you anywhere useful?)
The QR code doesn't generate a link, despite all my efforts. The part number (EAY65915332) doesn't bring up anything as LG.
I've tried all the obvious searches, even digging around on LG site for an hour, but I can't find anything. I thought it would be simple to order a spare PSU - I've done it with every other laptop I've ever owned.
Best I can do for a detailed pic:
tea for two wrote: Sat Dec 14, 2024 7:50 pm When I had a similar issue with my Asus laptop charging via usbC port, it was the usbC cable that couldn't deliver the required Wattage. I had to get a usbC Iniu 100W rated usbC charging cable that did the trick. Before this I had to get a usbC charger that outputted the required V, A,W for my Asus.
The Dell charger has a captive cable, so must be up to the job.
Here's the best shot I can muster:
If you stick LG before the part number when searching you get a few results in the US, but all over $100.
It’s a multi-voltage PSU, with several different voltages and corresponding power outputs, so I assume that there is some form of handshaking going on that selects the correct voltage for the connected item.
I expect that the Dell charger is either providing the wrong voltage or the laptop isn’t seeing the correct handshake and so not turning on the charging circuit.
I think this is the original unit:
https://www.chargerlab.com/lg-introduce ... f-devices/
MODEL: LP90DG20H-WW
Part No: EAY65915322
It appears to be a smart power supply offering a range of fixed output voltages and currents according to the Power Delivery (PD) format. However, it also includes a negotiable supply voltage for the receiving device over USB-C using the newer (and less common) PPS* format:
Output: USB-C, supports PD and PPS
PD Output: 5V/3A, 9V/3A, 15V/3A, 20V/4.5A
PPS Output: 5V-20V
I'm guessing the reason your alternative supply doesn't charge the battery is because it's not a PPS type able to negotiate with the laptop to provide the required voltage.
*PPS = Programmable Power Supply — this is an optional subset of the PD format. A USB-C PD supply provides fixed 5, 9, 15 and 20V supplies.
A PPS supply allows anything between 5 and 20V, depending on what the destination asks for, and is increasingly required for the best charging of lithium batteries.
The idea is to avoid the need for complex DC-DC conversion in the laptop, tablet or phone. Instead, that job is offloaded to the external psu, along with all the heat...
This 100W fast charger claims to support PPS and might be a viable spare:
100W USB C Plug, Anker Prime GaN 3-Port Fast PPS USB C Charger, Compact and Foldable Design, For MacBook Pro/Air, iPad Pro, iPhone 16/15 Pro, Galaxy S23/S22, Note20, Pixel, Apple Watch, and More https://amzn.eu/d/eKjbnK1
tea for two wrote: Sat Dec 14, 2024 7:50 pm The LG charger looks like LP90DGC20H-WW
An important necessary spec is the PPS on this LG charger : PPS is written inside brackets just after 20V 4.5A 90W.
PPS Programmable Power Supply is an important addition to standard PD Power Delivery of usbC chargers.
The Elf wrote: Sat Dec 14, 2024 8:28 pm
The Elf wrote: Sat Dec 14, 2024 8:50 pm Here's the best shot I can muster:
This Dell charger doesn't have PPS.
Searching online PPS 100W usbC charger throws up a few.
There's a 35squid Voltme USB C GaN 100W Charger PPS Quick Charge.
Also the Anker Prime 100W USB C Plug, Anker Prime GaN 3-Port Fast PPS USB C Charger Hugh linked to.
I'd go for the Anker.
Also using the usbC cable that was with the LG charger and or acquiring usbC cable stated delivery 100W or 120W or even 240W.
tea for two
Thanks for all this, guys.
So we've reached a point where we have 'smart' PSUs such that, despite having a 'dumb' PSU with plenty of capability to power a device, won't work. :headbang::lol:
And the batch of USB-C PSUs I bought last year are now redundant. :cry:
You couldn't make this stuff up...
I'm eyeing this:
https://www.amazon.co.uk/FINIBO-440W-US ... =8-22&th=1
The form factor suits me better ('normal' plug at the far end), and it seems flexible enough for future requirements. Can I hit the 'purchase' button?
Post by DGL. »
I would only buy one from a well known reputable manufacturer, some company who's name seems to be random letters, not for me thank you!
Your laptop would have been a decent amount of dosh so there's no sense in buying something that's not from a decent brand. Noting that Anker are a decent manufacturer.
The OEM PSU was probably made by Delta, FSP or LiteON and as such you'll probably find a suitable one made by them.
DGL.
The Elf wrote: Sun Dec 15, 2024 9:02 am I'm eyeing this:
It looks like it's trying to do too much at a cheap price, it's same price on auction site : although it has over 100 positive reviews on zon. For myself I wouldn't get it could be flakey could be alright, it could heat up a lot who knows.
I'd go for a known brand as Anker, the one Hugh linked to isn't trying to do too much.
tea for two
I really want to avoid that huge plug form factor. :(
Can anyone point me to a suitable alternative? :?:
It looks as if it just chucks out a variety of fixed voltage outputs, so I very much doubt it does any negotiating at all - very risky :(
Posts: 20880 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
The Elf wrote: Sun Dec 15, 2024 10:20 am I really want to avoid that huge plug form factor. :(
‘Huge’, when the one you liked had a giant rectangle attached?
You’re weird!
Folderol wrote: Sun Dec 15, 2024 10:20 am It looks as if it just chucks out a variety of fixed voltage outputs, so I very much doubt it does any negotiating at all - very risky :(
The two top 100W ports are PPS, so should provide variable voltage/currents and comms.
Wonks wrote: Sun Dec 15, 2024 10:27 am
Ahh! Didn't notice that - blame it on elderly failing eyesight:P
I think this may do the job but it doesn't actually say it's a PPS anywhere in the specs
https://www.amazon.co.uk/Belkin-Fast-Ch ... eature_div
The Elf wrote: Sun Dec 15, 2024 10:20 am Can anyone point me to a suitable alternative? :?:
tea for two wrote: Sun Dec 15, 2024 7:52 am Searching online PPS 100W usbC charger throws up a few.
Hugh Robjohns wrote: Sat Dec 14, 2024 9:19 pmhttps://amzn.eu/d/eKjbnK1
This Anker PPS is smaller.
100W rated usbC cable I been using an Iniu 100W rated usbC cable aboot a year.
tea for two
Wonks wrote: Sun Dec 15, 2024 10:23 am
You’re weird!
But the plug is a normal plug at the end of a cable. The box in the middle is less of a problem to ne. I want to avoid a huge plug at the plug end!
Drew Stephenson wrote: Sun Dec 15, 2024 10:33 am I think this may do the job but it doesn't actually say it's a PPS anywhere in the specs
Looks good in all ways, except no guarantees it would work.
If it doesn’t say PPS, then avoid.
Post by illegal colors »
The Elf wrote: Sun Dec 15, 2024 9:02 am And the batch of USB-C PSUs I bought last year are now redundant.
Try what you already have. You don’t need 90W to keep your battery from discharging. Try 65W or 20W. The newest smart devices often negotiate better terms with older chargers than with the latest and greatest from another manufacturer.
illegal colors
Posts: 110 Joined: Sat Jun 16, 2007 12:00 am Location: USA
The Elf wrote: Sun Dec 15, 2024 10:47 am
Looking at their website it would appear that GaN is the new angle on PPS (trying to cut through the chemistry/technobabble) - a quick search isn't throwing up any GaN chargers that aren't PPS.
Try it any see, it won't cost much for return postage.
GaN is just a semiconductor technology that produces less heat, making it useful in chargers (and LEDs)... but using GaN doesn't guarantee PPS compatibility.
The Belkin website lists these chargers as PPS compatible (and I dont think it includes the one you found):
https://www.belkin.com/uk/products/char ... rt=0&sz=24
