Hello, fellow Cubase users!
Is there a way for C14 Pro make a clump of notes perfectly in time as tuplets, e.g., triplets/5 notes/7 notes spread over one or even two bars (with the rest of the notes being “straight, non-tuplet” in nature), even though they were recorded with inaccurate timing?
I've tried using the Q panel, but for some reason it isn't working there like I thought it would.
Thanks for any help!
Cubase tuplets?
Cubase tuplets?
- alexis
Longtime Poster - Posts: 5281 Joined: Fri Jan 10, 2003 12:00 am Location: Hampton Roads, Virginia, USA
- alexis
Re: Cubase tuplets?
Select the notes you want to quantise, set quantise value to triplets - quantise!
If you want other notes quatised to other values... select them, choose a different quantise value - quantise!
- alexis
Re: Cubase tuplets?
Here's something for triplets, along the lines of what The Elf said, perhaps (I haven't tried it yet): https://www.youtube.com/watch?v=I_NQJcoUXGs&t=2190s
Still wondering about 5-tuplets, 7-tuplets, when spread across 2 bars.
- alexis
Re: Cubase tuplets?
I've never felt the need to place 5ths or 7ths over a 4/4 bar!
If I did...
Maybe easiest to record the 7 notes over 7 beats of 4/4 (i.e. bleeding into the second bar), quantise these, then use time stretch to pull the MIDI event back to a single bar.
I don't know of any DAW that has quantise to 5ths or 7ths.
If I did...
Re: Cubase tuplets?
The Elf wrote: ↑Wed Dec 18, 2024 9:43 pm I've never felt the need to place 5ths or 7ths over a 4/4 bar!
If I did...
Here's Greg Ondo, quantizing 5 beats over 1 bar, seems like it can easily be extended to 7 notes (like a fast sax run):
https://youtu.be/Tx4tNw8iRNw?si=ZvOPoQhSnhB9AErW
I think I'll learn to live without tuplets across two bars, though I found I was trying to play that the other day without meaning to.
- alexis
Re: Cubase tuplets?
More Greg Ondo on Cubase tuplets (placing 3 or 5 or 7 beats equally spaced across a measure or beat, etc.):
https://www.youtube.com/watch?v=0cIxyboY8Dg&t=3854s (good one)
https://www.youtube.com/watch?v=qHiTlmreJvg&t=6919s
https://www.youtube.com/watch?v=qHiTlmreJvg&t=6493s
- alexis
