Mastering Chain For Self-Produced Hip-Hop Tracks
https://drive.google.com/file/d/1FVxFiX ... sp=sharing
Alright, so this is a PDF listing my entire plugin database.
This is my current mastering chain:
Pro-Q 3
Weiss EQ1
Aquamarine 5
UADx Ampex ATR-102 Master Tape
Ozone 11 Imager
Black Box Analog Design HG-2
SPL Vitalizer MK2-T
Weiss DS1-MK3
smart:limit
What do y'all think? Feel free to Ctrl+F through my list and give some suggestions.
Does the order make sense?
Any plugins on the list do the same thing but better than a plugin in the chain?
Needs another limiter? Sky's the limit
Pro-Q 3
Weiss EQ1
Aquamarine 5
Ozone 11 Imager
SPL Vitalizer MK2-T
Weiss DS1-MK3
smart:limit
- blindishuman
- Posts: 1 Joined: Sun Dec 22, 2024 1:47 am
Re: Mastering Chain For Self-Produced Hip-Hop Tracks
It's more about what you do and why than which particular plug'ins you're using.
What are you using each stage here to achieve — and why at mastering rather than while you mix, where you have more control?
- Matt Houghton
Frequent Poster - Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Is that the chain you use, in its entirety? Because that is more destructive than constructive.
blindishuman wrote: ↑Sun Dec 22, 2024 2:30 am This is my current mastering chain:
Pro-Q 3
Weiss EQ1
Aquamarine 5
Ozone 11 Imager
SPL Vitalizer MK2-T
Weiss DS1-MK3
Could we hear one of your self produced Hip-Hop tracks with this chain.
- tea for two
I’m not sure a fixed chain is the right way to go.
I’ve worked a lot with Eric James, a professional mastering engineer, and he only adds processing when he needs to, and it’s usually limited to one or two compressors and one or two EQs. Which EQs and compressors Eric adds he decides by listening to the track and deciding what needs to be done.
I think most of those plugins don’t belong in the mastering phase.
The 'best' mastering chain is the one you chose with your ears, because the source material and target audience required it.
Im always a little smug when, after level matching my pre-mastered track to the mastered version, there is not a huge amount of real difference. It means (to me at least) the mix decisions were right
I have a standard mastering plug-in chain and template, but not everything gets used for everything and where it is used it's all song dependent.
Having things ready in advance does speed up the the set-up process but that's about it.
Drew Stephenson wrote: ↑Sun Dec 22, 2024 1:43 pm I have a standard mastering plug-in chain and template, but not everything gets used for everything and where it is used it's all song dependent.
Hopefully you've set everything to be in bypass by default when you first open the template.
Posts: 16991 Joined: Mon Sep 10, 2001 12:00 am
James Perrett wrote: ↑Sun Dec 22, 2024 6:53 pmDrew Stephenson wrote: ↑Sun Dec 22, 2024 1:43 pm I have a standard mastering plug-in chain and template, but not everything gets used for everything and where it is used it's all song dependent.
Yep, the default is 'nothing happens'.
The ds1 is amazing. Get rid of everything else and you’ll be in a better spot. It’s a weird compressor and it takes a minute to understand all the parameters but be patient with that one. It’s the best digital compressor I’ve ever used. If its too hard just use the mastering maximizer. Most of your plugins are buzz plugins. If your music isn’t sounding right its likely a production thing over a mastering thing.
I see you have almost every plug in ever created in your .pdf list which must have cost a fortune. We assume you have spent a very large sum of money on software and seem not to know what to do with it all.
I am going to read between the lines a little.
Do yourself a huge favour, get a professional mastering engineer with plenty of experience, exceptional monitoring and years and years of listening experience who is willing to provide a mix appraisal/feedback before mastering your track.
Many people do not need or wish for that but for those who do, it is invaluable assuming it is not a total mess and beyond the scope of feedback.
It will be the best money you have ever spent in terms of what you will learn and the end result.
Individual tool choice can really add a special edge to an engineer's work as their choice relates to being able to discern the cream of the crop. Often the tools used are chosen for a secondary, complementary/euphonic character beyond the primary remedial use, which might be EQ, compression etc.
The lion's share of mastering work is in response to detailed (and also broad) listening on a superb full range playback system. This informs as to what is done and what is not done, which are both as important as each other.
Seasons greetings to all !
- SafeandSound Mastering
Frequent Poster - Posts: 1670 Joined: Sun Mar 23, 2008 12:00 am Location: South
blindishuman wrote: ↑Sun Dec 22, 2024 2:30 amhttps://drive.google.com/file/d/1FVxFiX ... sp=sharing
Just now took a brief look see at this list. Apologies I chortled.
As suggested above in the various posts : would be the way to go.
As you have invested £$Tousands upon hardware software gear, see hear how you get on with just a couple Passive EQ, a single Compressor, a single Vitalizer as it were in your mastering chain. Goes without saying getting the mix as best as you can before adding any of these to the completed mix.
- tea for two
