Alternatives to Waves Plugins
Post by Blueflame »
Been systematically phasing out all my Waves Plugins, and only got a few left:
Smack Attack
Torque
Submarine
PuigChild
Abbey Road RS124
S1 Stereo Imager
The PuigChild I can swap out for another Fairchild. The RS124 is tricker because it does do a fee things that seem more or less unique.
The others must have alternatives though - any suggestions?
Blueflame
Posts: 2 Joined: Sun Dec 29, 2024 7:29 pm
Re: Alternatives to Waves Plugins
Post by alexis »
Would recommend a review of Melda Production's exhaustive catalog, seems like they have a plugin for everything!
alexis
Posts: 5284 Joined: Fri Jan 10, 2003 12:00 am Location: Hampton Roads, Virginia, USA
Acustica’s Cream 2 channel strip includes an RS124 compressor but may lack some of the features of the Waves version.
/https://www.acustica-audio.com/shop/products/CREAM
Currently reduced price and there seems to be a trial version available.
Post by Bob Bickerton »
I really like the Universal Audio Fairchild emulation - use it all the time - and is now has a native version, so you don't need UA hardware to run it (https://www.uaudio.com/uad-plugins/comp ... CiXRcYFn2x).
It's currently on special US$29 instead of US$299 (no brainer).
As to the S1, I use the SSL Fusion Stereo Image Plugin (https://store.solidstatelogic.com/plug- ... e-plug-in-) - expensive, but they pop up on special on a regular basis.
Bob Bickerton
Posts: 5637 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by R_A »
Blueflame wrote: Sun Dec 29, 2024 7:35 pm Been systematically phasing out all my Waves Plugins, and only got a few left:
S1 Stereo Imager
Mathew Lane Stereo Delta
R_A
Posts: 252 Joined: Thu Jun 26, 2008 12:00 am
Experimental / Ambient
https://www.rudiarapahoe.com
James Perrett and I both use Reaper’s own substitute for the Waves S1 Imager.
Martin Walker wrote: Mon Dec 30, 2024 12:51 pm James Perrett and I both use Reaper’s own substitute for the Waves S1 Imager.
Yes - the JS Stereo Field Manipulator does most of the things that S1 does. If you don't use Reaper then you can download ReaPlugs which allows you to use many of Reaper's effects as VSTs in other hosts.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by awjoe »
Bob Bickerton wrote: Sun Dec 29, 2024 9:28 pm I really like the Universal Audio Fairchild emulation - use it all the time - and is now has a native version, so you don't need UA hardware to run it (https://www.uaudio.com/uad-plugins/comp ... CiXRcYFn2x).
Thanks very much, Bob.
awjoe
Posts: 5575 Joined: Tue Mar 08, 2011 12:00 am
I bow down before your superior biscuitular capacity.
Post by Blueflame »
Thanks. I do use Reaper and wasn’t even cognisant of this stock plugin!
Blueflame
Post by IAA »
Not to get into a “this is better than that debate”, but when I reviewed my plug ins during my last Mac upgrade I was very impressed by the Logic Pro stock compressors, reverbs and eq. In fact I’d say to my ears they were as good as some from respected third parties that I subsequently bought. So this check seems useful I’d say before any purchase.
Sometimes because it’s a stock plugin I used to ascribe it a somehow lower status than some whizz bang thing discounted by 90%. A learning point for me too.
(I know I kinda have got into the comparison thing, but not as the main point)
Ian
IAA
Posts: 1621 Joined: Fri Dec 28, 2007 12:00 am Location: York
Blueflame wrote: Wed Jan 01, 2025 3:58 pm
It is well worth spending some time in the JS folder. There's a great Stillwell Aural Exciter and a similar Bass Enhancer in there as well as General Dynamics which is a very versatile dynamics controller. You can also create some fairly advanced processing by stringing together some of the basics in a novel way.
If you can't find what you are looking for then try the Reaper Stash
https://stash.reaper.fm/
where there are all kinds of user generated effects, themes and other goodies.
James Perrett wrote: Thu Jan 02, 2025 3:37 pm It is well worth spending some time in the JS folder. There's a great Stillwell Aural Exciter and a similar Bass Enhancer in there as well as General Dynamics which is a very versatile dynamics controller. You can also create some fairly advanced processing by stringing together some of the basics in a novel way.
I'd already created my own basic presets for the Stereo Imager, Aural exciter and Bass Enhancer (but still largely forgotten about the latter two since then).
However, I hadn't explore the Reaper Resources before - what a revelation, and what generosity from other reaper users!
If you know even a little about coding, clicking on the Edit button inside any of these fx can also be a revelation, when you realise how few lines it takes to perfectly reproduce some well known paid effects :shocked:
Post by Zukan »
Reaper is so cool! However, maybe Blue doesn't use it so...
I use IK Multimedia, Acustica Audio, Tokyo Dawn Labs, FabFilter and PSP as my main 'go tos'. However, I love supoorting smaller companies and buy depending on functionality as opposed to brand.
It's a great time to load up on plugins as everyone and their pets are scripting.
Zukan
1-2-1 Tuition
Post by jimjazzdad »
And then there is Airwindows. I think Chris is brilliant but I wish I had more time to play with/learn his stuff. There's a lot of it.
jimjazzdad
Posts: 310 Joined: Sun Dec 15, 2013 12:00 am
Halifax, NS, CANADA
jimjazzdad wrote: Fri Jan 03, 2025 11:39 am And then there is Airwindows. I think Chris is brilliant but I wish I had more time to play with/learn his stuff. There's a lot of it.
Chris Johnson has developed and released hundreds of Airwindows plugins over the years, so the choices can be a bit overwhelming at first, especially as you don't get any instructions, and the GUIs are basic in the extreme.
I've whittled things down to 60 carefully chosen items in my Airwindows folder, but if you're starting out, it's a lot easier to instead use his Consolidated multi-effect plugin that collects all 400 effects together into a single 8MB downloadable file that runs on Windows, Mac or Linux.
Consolidated also includes integral onscreen documentation, and some suggested parameter settings to achieve specific results, and to help you wade through everything you can narrow down the options by switching from 'All plugins' to much more restricted choices including Basic, Latest, or Recommended.
https://github.com/baconpaul/airwin2rac ... /DAWPlugin
Well worth exploring!
Zukan wrote: Fri Jan 03, 2025 8:10 am Reaper is so cool! However, maybe Blue doesn't use it so...
He does...
Hence my further suggestions.
I've also started to explore the Tukan JS plug-ins which cover quite a few bases and may appeal to those who like their plug-ins to look like the gear that they are emulating.
https://www.realinks.net/links/tukan-jsfx-pack/
will take you to an introductory page.
Post by Zukan »
Teaches me to read all responses thoroughly...sigh.
Ignore my advice. Good looking out James.
Zukan
1-2-1 Tuition
