Brain exploding: Ethernet connection for AudioGridder
Re: Brain exploding: Ethernet connection for AudioGridder
Post by merlyn »
What was the output of ping? If I ping 8.8.8.8 (a Google DNS server) I get this:
Code: Select all
$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=116 time=26.9 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=116 time=24.2 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=116 time=24.5 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=116 time=24.7 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=116 time=22.9 ms
^C
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 22.869/24.618/26.853/1.283 ms
If the direct connection is being used in your setup, the time should be tiny.
merlyn
Post by alexis »
merlyn wrote: Mon Jan 06, 2025 7:33 pm What was the output of ping? If I ping 8.8.8.8 (a Google DNS server) I get this:
Code: Select all
$ ping 8.8.8.8
^C
Thanks for checking on this, merlyn!
The numbers were very small when I did it, pinging from DAW computer to server computer:
Code: Select all
 Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1 bytes=32 time <1ms TTL = 128
Pinging statistics for 192.168.0.1:
     Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
     Minimum = 0 ms, Maximum = 0ms, Average = 0ms[\code]
alexis
Posts: 5284 Joined: Fri Jan 10, 2003 12:00 am Location: Hampton Roads, Virginia, USA
Post by alexis »
Continued (due to formatting problems):
Pinging from the server computer to the DAW computer resulted in similar numbers, with three of the four R/T being < 1 msec, and only 1 being equal to 1 msec.
These seem like good numbers, or is 1 msec round trip time for even one of 4 packets sent from the server computer to the DAW computer eye-brow raising, or possibly just overtly long enough to suggest problems?
Thanks again!
PS: I repeated a ping in the Server computer>DAW computer direction and found the R/T times to be = 1msec for three of the four, and < 1 msec for the fourth ... are all these tests showing basically the same thing?
alexis
Post by merlyn »
The figures look good and consistent with a direct connection. To see if I could connect to another machine I would use ssh. This allows you to log into another machine. You could also try network sharing a folder, and seeing if you can access that from the other machine. If you can then the two machines can connect and the problem must be with an Audiogridder setting.
merlyn
Post by alexis »
merlyn wrote: Mon Jan 06, 2025 8:35 pm The figures look good and consistent with a direct connection. To see if I could connect to another machine I would use ssh. This allows you to log into another machine. You could also try network sharing a folder, and seeing if you can access that from the other machine. If you can then the two machines can connect and the problem must be with an Audiogridder setting.
That's what I tried, and it took me FOREVER (somehow I had to put both computers in airplane mode, not sure why, and none of the vids mention that; also believe it or not I wound up with copying someone's preferred DNS server addresses and entering them. Yes I also donned a druid costume and turned around three times with a dead fish in each nostril, it absolutely took all these things to make it work).
But in the end I was able to share a folder between the two computers, and lo and behold when I then fired up Audiogridder it woke up on the DAW computer automatically connected to the server computer and working!
Thank you so much merlyn, you pointed me in the right troubleshooting direction several times, without your help I don't know how long it would have taken me to get through this area I knew absolutely nothing about before, it would definitely have taken a lot more fish that's for sure.
You da man! :clap::clap::clap:
alexis
Post by merlyn »
I'm glad you got it working. Using airplane mode makes sense as this means wifi is definitely off. Audiogridder uses mDNS for its connection process, so there could have been something going on there. DNS turns something human readable like www.soundonsound.com into a numerical ip address. As you were already using numerical ip addresses I wouldn't have thought that would be an issue. Still, you got there in the end. Good job!
merlyn
Post by alexis »
:thumbup: As it turns out putting each computer into airplane mode is what pushed me over the finish line in terms of being able to access the "other" computer under the respective "Network" tabs, which is what I tried to set up for an eternity in preparation for trying Audiogridder itself for the nth time. This site, https://techwiser.com/how-to-connect-pc ... lan-cable/, was typical of most I found on line to help me do that (for others that may follow, I hope this saves you hours and hours of time!), though exactly zero of the sites mentioned airplane mode.
I just wonder, would someone with experience in connecting computers have just instinctively said something "Well, let's see if it needs airplane mode to get it going"? I imagine that might be the case because no one mentioned that in any of the online instructions!
There was absolutely no logical reason for me to try airplane mode given my knowledge base, I'm not sure I even remember consciously trying it. I felt like one of those monkeys with a typewriter charged with writing Shakespeare - give me enough time and stabs at my keyboard, maybe something useful will turn up* **! :lol:
*Except none of those simians had merlyn in their corner! :D
** Though apparently the Infinite Monkey Theorem from my youth has been trashed, https://www.sciencealert.com/scientists ... hakespeare, like the concept that Pluto is actually a planet and so many others, what's even left that we can count on anymore?! Waaah! :lol:
alexis
alexis wrote: Tue Jan 07, 2025 3:14 pm I just wonder, would someone with experience in connecting computers have just instinctively said something "Well, let's see if it needs airplane mode to get it going"? I imagine that might be the case because no one mentioned that in any of the online instructions!
No - I wouldn't have put it airplane mode because that mode never existed when I started doing PC networking. What I might have done is to disable any network interfaces that I didn't need for the particular task in hand - which is probably what airplane mode does (but with a fancy name). However, setting IP addresses and domain name servers is something that anyone who wants to use networking in anything more than its most basic form needs to understand.
One thing that I probably need to remind you is that 90% of what you see on YouTube and read on the Internet is rubbish written by people who don't know anything more than you do. I suspect that you've taken all these dubious sources, given them more credence than they deserve and ended up totally confused.
The basics of networking haven't changed for 40 years - if you learn the foundations before you try to build the roof you'll find that everything else falls into place much more easily.
If you remove airplane mode and check the IP address(es) assigned to the wifi, are they 192.168.x.x (where x is any number)?
If so, then you could probably 'fix' it by changing the IP addresses on the direct connection as described in this post I made yesterday. That said, if you don't need wifi on those machines then I'd leave it alone as it works :D
Posts: 9985 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by OneWorld »
James Perrett wrote: Tue Jan 07, 2025 4:08 pm ...............
I concur, and once those foundations are understood, networking is not the 'dark art' it is presumed to be, it is so logically 'pure' that it is hard not to understand. That said, when friends of mine said they were having internet trouble with that and that I'd say to them "If you understood the complexity of it all, you'd probably conclude it ever worked at all, so if you can't connect, get on with your day, make a cuppa whatever and by the time you're done it'll be working again"
I wonder if 'airplane' mode is demanded by the software itself? though I very much doubt that
OneWorld
Posts: 5959 Joined: Tue Apr 07, 2009 12:00 am
OneWorld wrote: Tue Jan 07, 2025 5:01 pm I wonder if 'airplane' mode is demanded by the software itself? though I very much doubt that
My hunch is that the DHCP server in the broadband router is allocating 192.168.*.* addresses, causing a routing conflict with the static wired configuration.
Disabling the wifi card would disambiguate that, leading to a working direct connection which would explain why airplane mode makes a difference.
Post by alexis »
Undoubtedly true :thumbup: Nothing came easy here.
Another way to look at it however, for better or for worse, is that I wanted to get on with using AudioGridder and making music as soon as I reasonably could.
Kind of like (sorry, I suck at analogies) leaving for a trip to Turkey in a week but wanting to communicate with the natives in their own language when I get there. I can do it right and delay the trip till I take a 6- month course in basic Turkish, or leave as scheduled and depend on a phone translator app. I really won't learn much Turkish with the app, but at least I'll get to there on time.
Despite all that, with your help and help from others :):) , I did "learn some Turkish" in this process. I now know a bit about ethernet cables and their wiring, static ip addresses, navigating the myriad Windows windows and menus needed to link two computers with a cable, and how to transfer files and folders through a cable, and more.
I do wish I had learned a bit more about ip addresses (I didn't know you could just make them up!), and more.
But I am using AudioGridder now, so I'm OK with that - for now.
Thank you again! :):)
alexis
Post by alexis »
Eddy Deegan wrote: Tue Jan 07, 2025 4:39 pm If you remove airplane mode and check the IP address(es) assigned to the wifi, are they 192.168.x.x (where x is any number)?
Hi Eddy!
Sorry, I haven't been able to answer because: I've been away from that computer for a bit, and also - the behavior seems variable and a little puzzling to me still.
To answer your question: when I remove airplane mode the IP addresses and network mask are exactly as you typed/suggested in your linked-to post (though I can't be entirely sure which post you are referring to, as the link brings me to the top of the first page) and I entered back then, as below. (I think you may have since mentioned that the Default Gateway entries don't matter, but for completeness' sake they are 192.168.02 for Computer 1 (Server) and 192.168.0.1 for Computer 2 (DAW Computer). Additionally, the DNS Server addresses I entered in each machine were 208.67.222.222 for the Preferred DNS Server, and 208.67.220.220 for the Alternate DNS Server, all this from another user) ...
I'm having successful network connection (at least as I know it might be defined, by sharing files/folders residing on one computer from the other, bidirectionally), but unfortunately only intermittently. Trying to see why, I've noticed that at times I can have a good connection with the each of the following parameters toggled to both on and off:
1) Airplane mode
2) Password protected sharing on "All Networks"
For example, this evening (after a full day away) the network connection was non-functional. All it took to make it functional was to turn Password protected sharing on "All Networks" to "Off" - even though when I last used the computers it had been set to "On" and network sharing was fully functional!
Parenthetically, WiFi is enabled and active, yet network sharing is working - for now!
It's almost as if the requirements for a successful network connection vary over time ...?
Anyway, thanks for your interest. I'll keep observing and trying to find a pattern I can use to modify my settings. In the meantime, if the Audiogridder DAW computer becomes blinded to the server computer all of a sudden, I know how to toggle several parameters back/forth to get the network up and running again. Not ideal - but workable.
Thanks again, Eddy!
Code: Select all
Machine 1: IP address 192.168.0.1, network mask 255.255.255.0
Machine 2: IP address 192.168.0.2, network mask 255.255.255.0
alexis
alexis wrote: Thu Jan 09, 2025 1:10 am
I'm still not sure that you've grasped the basics yet so you're making lots of errors. Once you sit down with an authoritative book on the subject it will all fall into place. If you just keep stabbing at buttons hoping something will work then you'll continue to get random results.
Post by alexis »
James, thank you for your help and attention to my networking problems, and others I've posted on previously. :):)
One thing that I probably need to remind you is that 90% of what you see on YouTube and read on the Internet is rubbish written by people who don't know anything more than you do... :lol: .
Yes sir, that's one reason I come to this fine forum! :) I'm also fortunate that my wife has more knowledge about networking computers than I, and she was able to help as well.
But additionally, though what you wrote is a good warning, I was able to get a good sense who on line posting "How To ..."- type instructions knew what they were talking about and who didn't, in part by seeing what recommendations were made consistently across sets of instructions. It would have been very hard when I started out looking for how to network two computers for anyone to not know more than I - I knew literally nothing then I :lol:
James Perrett wrote: Thu Jan 09, 2025 2:16 pm
You are 100% correct again, of course!
James Perrett wrote: Thu Jan 09, 2025 2:16 pm ...If you just keep stabbing at buttons hoping something will work then you'll continue to get random results.
Point well-taken, though I've done enough searching for how to network two computers, and received enough help including from very kind people on this very forum that I wouldn't use the term "stabbing at buttons" to describe what I'm doing :)
James Perrett wrote: Thu Jan 09, 2025 2:16 pm ...Once you sit down with an authoritative book on the subject it will all fall into place.
Yes, I'm sure you're 100% right! I'm also trying to make music now, so as always time constraints present a challenge.
Would you recommend a specific authoritative book on computer networking, for beginners, that might give an overview helpful for computer musicians?
Thank you again:)
alexis
Post by merlyn »
Once you set up a connection it should stay that way. If you think about it, it has to. I have my old computer on the network, and it's set up headless, i.e. no mouse, no keyboard, no monitor. I can use my old computer through VNC, so I get the old computer desktop on my new computer over the network. If I couldn't connect to the old machine, I would have to plug in a mouse, keyboard and monitor on the old machine to fix it. A complete pain.
I have generally found that networking works pretty well, as IT guys rely on it to administer the thousands of headless machines in the world.
A couple of points -- (1) using a direct connection between two machines is unusual. (2) I think the randomness is due to having wired and wifi networks.
What Eddy suggested was setting the ips to 10.0.0.1 and 10.0.0.2, then you'll know that they're not being set by your router over wifi.
Now that you've used ping, you can try another diagnostic tool. It's called tracert on Windows, and will show you the route packets take. If you are are using a direct connection, there should only be one hop. If wifi is somehow being used, there will be a hop to the router, then a hop to the other machine.
merlyn
alexis wrote: Thu Jan 09, 2025 3:16 pm
I learned it from an Open University course which covered the subject fairly well although I can't find the relevant textbook at the moment - either my lad has it under his bed or I lent it out to someone.
I'm a bit out of touch with current computer textbooks but, in the UK, most of the A-Level computer science syllabuses cover the basics of IP networking so there are textbooks to go with those that cover many aspects of computing. You probably have something similar in the US education system. They won't tell you exactly what to enter in each part of the dialog box but they will tell you the principles so that you'll easily be able to work out what each entry means.
I also think you have made the mistake of trying to incorporate aspects of answers from multiple sources without necessarily understanding why they differ. Computing is a very exact science - if you try to treat it in any other way it won't work. So try each suggestion completely and then, if it doesn't work, try another suggestion. Don't try to combine facets of multiple suggestions at once unless you are an expert.
As an example - you mention entering an address for a domain name server. There's absolutely no need to even think about domain name servers for your application - raw IP addresses should suffice.
Post by alexis »
Thanks again, James, very helpful as always :)
alexis
Post by OneWorld »
alexis wrote: Thu Jan 09, 2025 6:39 pm Thanks again, James, very helpful as always :)
I'll try and reduce it down to elementals. I had mentioned earlier, the analogy of the telephone network.
The two types of network: a Domain and a Workgroup
Domain - a server is used to administrate the network, This is not usually used in a smaller, say home network with a few computers, setting up a domain isn't justified as in a domain you have a server to administer the network, and that server runs 24/7
Workgroup - all devices on the network share resources and data, but no one computer functions as a server.
The job of a server - it acts as a gateway, from the Intranet (a network in an organisation) to the outside world - the internet.
Each device on a network needs a unique ip (internet protocol) address. The server using Dynamic Host Control Protocl (DHCP) dishes out those addresses and in doing so avoids conflicts (2 or more devices having the same address)
The dynamic part of this is....imagine a company with say 100 computers and some printers etc Bear in mind, a network operating system includes a number of 'seats' as part of the licence, more seats, the more costly the software
Now imagine that company has 50 employees, so it only needs 50 seats, although it has 100 computers. But not all of those computers could be used at the same time, there are only 50 'seats' and when computer number 51 were turned on (imagine there are contractors employed on an ad hoc basis) the DHCP in the Network Operating System would say "Sorry licence limit reached - buy more seats" but, the Wages Department has closed down for the day, so the contractor could go and log in to one of those computers, but no, the wages department is a secure area and closed off, and it has 10 computers in there, not being used.
DHCP will say Hmmmm, there are 10 ip addresses assigned to computers not being used, I'll borrow ip addresses from there, or more precisely the licences, in other words I can release those licences (and ip addresses) and assign them to the other computers the contractors have just turned on.
That is the Dynamic part of things. In practice the ip addresses can remain static, but the DHCP can assign addresses as and when, you might have a 100 or whatever number of computers/devices, but only 50 in use at any one time.
Also the server is a central repository for data files, that way there is managed file sharing and backup. Depending on company policy, the server can monitor traffic going in and out of the company computers, so for example the users cannot download and install all manner of trish-trash, and viruses! if a client computer does become affected, it is far easier to isolate.
The server will also serve as a mail exchange, so all emails coming in and out of the company are managed.
Bear in mind there are many different aspects to the internet - ftp, www, telnet......etc we often think of the internet and the web as one and the same thing when in fact the internet is a suite of things, the server OS can handle any of those.
Much of the software used on client computers will just be 'front end' the data itself be kept on the server, a database being a case in point, that way each employee can have access to the database instead of each employee having a separate version on their workstation. IM have known some companies where employees would copy data onto USBs and pass them around the other users in the company to keep the data consistent. Between 2 or 4 computers, yes ok - but 50, or 1000!!!!
The Workgroup - a much simpler setup, each computer is independent of each other, they have no common central meeting point. But are connected so they can share files, and one could be assigned as a Quasi server, where shared files can be kept.
But what about ip addresses? Well each computer can be assigned a static address. But more likely, there will be a router, to connect to the internet, and that will dish out ip addresses, by way of DHCP and by way of using a NAS, a central repository for files can be kept, with the NAS having it's own address, is kept switched on and thus files be available to any user with the requisite permissions. By using a router and NAS you have sort of a toy domain, but no way as complex as a domain server
IP Addresses - typically 192.168.1.1 (up to 255) 255.255.255.255
255x255x255x255 - a lot of numbers eh - I think it stacks up to about 6 billion, that's plenty? Well not so - because the number of devices in the world is increasing, with not just computers being on the internet, but cell phones, cars etc etc etc so now we have a different system, but for our purposes lets stick with the 255.255.255.255
Some ip addresses are as good as fixed - 10.0.0.1 is often used for localhost (the server)
There are others but lets stick with 192.168.x.x (192.168.1.1 for example)
What concerns us is the last two 1.1
The last number '1' is the device number, so say you have 4 devices PC, tablet, phone, printer...so they will gt the addresses
192.168.1.1
192.168.1.2
192.168.1.3
192.168.1.4
192.168.1.255
and 255 devices is more than enough? Nope, what if you have a company with 300 computers (for example)
What you do is set up a subnet and you get is....
192.168.2.1
192.168.2.2
192.168.2.3
192.168.2.4
192.168.255.255
But you might say "Hang on a minute, my computer has the ip address 192.168.1.10" (for example)
And my pal up the road has a computer and that has the same ip address?
Yes, but that is only within your little home network, your router address though will be assigned by your broadband company, so you have a network that is a subnet of the top level network.
Instead of pinging an address, try this, the trace route (tracert) option
tracert www.bbc.co.uk
You'll see the hops the request goes through, showing the different networks
When you add a device to your home network, you might use ethernet cable, which plugs into the network interface card (NIC) in your computer and it is the NIC that picks up the ip address from the router, but usually home routers only have 4 ethernet ports, though you can add another internet switch/hub which will have 4 or more additional ethernet ports, or more likely use WiFi where you are not limited by the number of physical ports.
Your router serves as a gateway, same as a server does. I have come across some routers that have a firewall built in, in the same way server does and the router might have basic config options, eg block sites etc
Cellphones - how do they stay on the network? Well every time you turn your phone on, it looks for the nearest mobile mast, and when you're travelling about, your phone is constantly being pinged, and as you travel you'll pass from one cell to the next, DHCP on the move, the cells being organised using a structure known as tesselation, which means there are more shared borders between cells than if the cell were circular shaped or box shaped, tesselation is octagon shaped, giving seamless contact - well most the time. Additionally, cell phones can employ bandswitching, there will be a range of frequencies available and within that spectrum are different slices of frequencies. When one frequency gets busy, signals are switched to less busy ones - as ethernet DHCP can dynamically assign addresses.
Are you still awake? Well I had hoped to keep this simple, but half way along I thought I started so I'll finished. I amazed by the technology, it's a wonder it works at all.
OneWorld
Post by alexis »
This was a work of beauty and clearly love of the field, OneWorld ... thank you so much!
I went looking for a way to pin this, and lo and behold I'd forgotten the forum has a bookmark function - it's now bookmarked, for frequent future reference.
Making headway!
alexis
Post by 2pods »
That was the best explanation of networking I've ever read.
I hope you don't mind, but I've saved that, to save me much brain ache in the future.
So far, anything I've done with networks have just worked (routers, switches, multiple computers, smart devices, using a second router as an add on, etc.), so I've been lucky.
Thanks OneWorld
2pods
Posts: 83 Joined: Tue Oct 12, 2004 12:00 am
Post by ajay_m »
Networking can be... fun... particularly on a machine which is multi-homed (i.e has more than one network adaptor).
A long while ago I worked out how to get wireless MIDI working with a Raspberry Pi, and created a very detailed step-by-step guide, which can be found here https://stash.reaper.fm/v/30519/wireless%20midi.rtf
This walks through some basic networking concepts in some detail and - as a useful side effect - you end up with a cheap and functional wireless MIDI solution that'll connect to a standard DAW using the amazing rtp-midi project.
ajay_m
Posts: 1677 Joined: Mon Jan 16, 2017 7:08 pm
Post by OneWorld »
Thanks for your comments alexis and 2pods
I came to networking in many circumstances, a melee of circumstances that had me setting up networks though I was clueless. My background was in coding, AI of all things - computational linguistics being my area of expertise.
2 friends of mine had set up a small company with the remit of a 'complete solution' ie, going into a company and assuming complete responsibility for all a company's and organization's needs. We worked in the SME sector.
So far so good. Except just as contracts started to roll in, my two friends who were networking experts were given a very lucrative contract, an offer they simply could not refuse, but they had signed a few contracts to set up networks in a few companies who had already placed orders for a van full of new computers, printers etc
So they roped me in, and gave me an hour or so crash course on networking and I was literally dumped into a company, with a heap of computers to install, configure and leave the clients as happy as Larry - OMG talk about a baptism of fire, you have several floors of users, none of them can log on, the server has gone down, the broadband supplier is being changed and the new modem hadn't arrived, email was being bounced back, the hardware firewall wasn't playing, just playing up (they are pig to set up - stay thee away!!!) the remote users couldn't connect.........and now it's pay day and the finance officer had no access to the wages software and PAYE tax portal, and so on, and I'd only been there 5 minutes! and the boss of the company saying "Each employee represented a cost of £50 an hour, and currently he has 30 employees sat sucking their thumbs because of..........me. I just said "Never mind, nothing's good that's rushed and in a 100 years no one will give a hoot anyway"
To be fair, there were employees that gave me support and said they would have lost the will to live by now LOL And usually it was the young lasses that were most helpful, they would make me cups of tea and share their lunch, and they say "How do you do this without going crackers?" I said "What would it change if I did?"
Point I am making is, one becomes a quick learner and over the years the bosses of those companies all showed their thanks. One in fact was quite an established jazz guitarist and we spent hours talking about guitars, performances, this artist and that till it got to the pint where I had to remind him "Do you realise you're paying me £50 an hour to sit here jazzing about?" I wasn't getting any work done.
So all in all I would not have gone into the whole thing if it were not happenstance, that said, we all like adventure, and we always seem to learn best from our mistakes and over all the years I never once left a setup worse than what I found it and never lost data. I was offered a full time job as the company grew, but I'd had enough and was offered a lecturer's job at a local university - it is easier to talk about something than actually do it!
I look back on those days with fondness sometimes, I learnt such a lot and getting a company setup with all its computers chugging away, fast internet, predictable and unfettered use gave me a feeling almost as good as finishing a set with the band I was with and it was 'just so'
OneWorld
Post by alexis »
OneWorld wrote: Fri Jan 17, 2025 2:56 pm Thanks for your comments alexis and 2pods
I came to networking in many circumstances...
Now that is a cool story, thanks for the telling, OneWorld!!
I look back on those days with fondness ... gave me a feeling almost as good as finishing a set with the band I was with and it was 'just so'
Now that is saying something!!! 😊
alexis
Post by OneWorld »
alexis wrote: Fri Jan 17, 2025 3:08 pm
There was one time where a solicitor's office called us in. As part of the job remit, the lead partner's wife said she suspected there was in-appropriate material on the network and she asked me to look through the data to see if there were any evidence of that. Of course I did my duty and found that yes, there was hanky panky and compromising stuff being exchanged between two of the staff, one an office junior and the other.....her husband!
Not long after the place closed down and divorce proceedings followed, we made sure we got paid first!
OneWorld
