How Do They Get This Stereo Bass Thing?
Post by Jathon Delsy »
On the two tracks linked below, Justin Timberlake "SexyBack" and Justin Bieber "Friends" they have a similar stereo synth bass sound.
How is this done?
To me it sounds too incisive to be a chorus effect. Is it perhaps done by doubling the part and panning it hard to each side and delaying one side? Or another way.
Thanks.
https://www.youtube.com/watch?v=3gOHvDP_vCs
https://www.youtube.com/watch?v=BldYlGqs7pA
Jathon Delsy
Posts: 205 Joined: Fri Dec 05, 2014 12:00 am Location: London, England.
Re: How Do They Get This Stereo Bass Thing?
Post by yeroc »
For this effect I typically use Soundtoys Phase Mistress or MicroShift. I set it by ear and visually with Voxengo’s SPAN on the M/S overlay mode!
But there’s plenty of other alternatives and home cooked ways to do a similar hass effect + M/S eq.
yeroc
Posts: 219 Joined: Tue Jun 16, 2020 5:54 pm
So it's done using the Haas effect? I suspected so.
Does this mean a delay under 30ms?
And are the sides equalised differently, or phase shifted too?
Jathon Delsy
Post by SafeandSound Mastering »
2 very different bass sounds, if Justin Timberland's track even has a bass line, sounds like a kick drum that is producing what I would call bass. There is a kind of stab that appears later which is more lower mids than bass.
The Bieber has a kind of low pass filtered 16th note saw wave (synthwave style) bass and it sounds like oscillator unison/chorus effect to me.
Use any virtual analogue synth with a single saw wave oscillator.
Add voices and or/spread to a LP Filtered saw tooth bass and see where you end up with that note pattern. You may want to use an envelope to control the cut off to achieve the desired rolling effect.
Always check mono compatilbity with stereo basses You can always use a narrower-izer on an insert if the synthesis results in a too wide sound. Then balance / mix it post narrowing. (continuing to check mono compatibility / level in mono)
Hope that helps.
Posts: 1670 Joined: Sun Mar 23, 2008 12:00 am Location: South
Mastering: 1T £30.00 | 4T EP £112.00 | 10-12T Album £230.00 | Stem mastering £56.00 (up to 14 stems) masteringmastering.co.uk
