Piezo bug pick-ups
Piezo bug pick-ups
I'd like to add a pick-up to my guinjo so that I can plug it straight into my pedal board.
I don't think an under-saddle option is practical so I'm looking at the various bug options. K&K have been recommended but as I'm a cheapskate, and as the instrument cost less than £10 to make, I'm looking for any other budget recommendations.
The key thing is that I don't have room on my pedalboard for another power-supply or pre-amp - otherwise I'd use my Zeppelin Cortado.
Cheers
Drew
Re: piezo bug pick-ups
Someone needs a bigger pedal board!
The time comes to us all.
A K&K hotspot is just under £40, so you're looking for something cheaper that doesn't need an external preamp or needs to feed into a 10meg input impedance input.
Lots of £10 bugs on Amazon. No idea how they sound but some get decent reviews (those that have actually tried with placement and not just stuck it on without testing). A lot seem to have 2.5mm micro jacks at the piezo end though, with a fairly short (10') supplied lead.
Post by BigRedX »
£40 for a piezo bug that doesn't require a pre-amp is cheap in relative terms. IIRC the Ibanez piezo bug I bought for my acoustic guitar in 1975 cost £15 and was very average sound-wise.
I've just had a look and second-hand versions of the Ibanez are in excess of £50 which means that the Kimbara acoustic guitar that it's fitted to has now tripled in value!
BigRedX
Wonks wrote: Wed Jan 15, 2025 10:53 am A K&K hotspot is just under £40, so you're looking for something cheaper that doesn't need an external preamp or needs to feed into a 10meg input impedance input.
Actually that's in range. Most of the hits I was getting were a lot higher than that. I plainly need to brush up on my google-fu.
Wonks wrote:Lots of £10 bugs on Amazon... A lot seem to have 2.5mm micro jacks at the piezo end though, with a fairly short (10') supplied lead.
That would work because I can attach that tail to the strap.
BigRedX wrote:£40 for a piezo bug that doesn't require a pre-amp is cheap in relative terms.
Agree, not sure how I'd missed that in my searches. :headbang:
I'll see if anyone has any hands on experience with one of the Amazon jobs and if not see what can be negotiated out of the toys budget.
One question to ask yourself is "Do I actually want it to sound like a £10 instrument"?
Wonks wrote: Wed Jan 15, 2025 11:21 am One question to ask yourself is "Do I actually want it to sound like a £10 instrument"?
Well that sounds like an improvement ;)
Posts: 13295 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Re: Piezo bug pick-ups
A good way to amplify a banjo-style instrument is to glue a large brick to where you’d normally stick a piezo element, then throw it down a well, where it will make a satisfyingly loud splash at the bottom.
Post by Tomás Mulcahy »
The brick is excellent advice IMHO :)
They don't give any specs that I could find anywhere- but it looks like there is no pre-amp so it is still a passive piezo that requires a hi Z pre amp.
I think the Triton Big Amp Piezo pre-amp is small and a useful thing to have around, and very reasonably priced. I have a 5 packof piezos I bought from Amazon for something less than £20. Two of them match and I get beautiful sounds with a pair of Tritons.
Last edited by Tomás Mulcahy on Wed Jan 15, 2025 12:18 pm, edited 3 times in total.
Tomás Mulcahy
:tongue:
Tomás Mulcahy wrote: Wed Jan 15, 2025 12:06 pm The brck is excellent advice IMHO :)
There are different Piezo materials and K&K pickups have a strong output and actually prefer a lower impedance to run into, so you’re fine running it into a line input on a mixing desk.
I’ve fitted them to several instruments and although K&K themselves say 500k to 1 meg, I have modified a clean boost pedal with to have a 10k input impedance as that’s where it actually sounds flattest to me (my Fishman loudbox mini has a 10 meg input impedance and it sounds very boomy indeed plugged straight in, hence the pedal).
Tomás Mulcahy wrote: Wed Jan 15, 2025 12:06 pm I think the Triton Big Amp Piezo pre-amp is small and a useful thing to have around, and very reasonably priced.
But that requires phantom power, which means adding a power supply and then converting the output to go to the pedalboard.
Good to know thanks!
How does the K&K sound compared to the Cortado?
Tomás Mulcahy
Yes it took me by surprise as well, I was expecting the opposite.
Drew has the Cortado and my K&Ks are all under-bridge mounted, so I can't say how they compare myself.
Post by shufflebeat »
Yoga D-606 cheapo drum mic clamped inside and low/hi Z adaptor (backwards DI) to match it to pedalworld.
https://www.amazon.co.uk/Pulse-D606-To ... B0CPDPYR1K
Forget the rim-clamp included, there are much better ways to fit it.
shufflebeat
JJB Electronics do K&K typ pickup systems for a lot less money.
https://www.jjb-electronics.com/our-products.html
The only UK stockist I've found so far is Feline Guitars but he only seems to have the Prestige system in stock which is the most expensive JJB make.
https://felineguitars.com/collections/j ... ic-pickups
I've just bought one to fit to my Brian Eastwood acoustic.
Sam Spoons wrote: Wed Jan 15, 2025 2:45 pm JJB Electronics do K&K typ pickup systems for a lot less money.
Not for the single disk version. Cheaper in the US but not over here with shipping etc.
Post by adrian_k »
Drew I think I can help - will PM you.
adrian_k
Posts: 3813 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life is wealth. (John Ruskin)
adrian_k wrote: Wed Jan 15, 2025 4:00 pm Drew I think I can help - will PM you.
Received and PM'd. :thumbup:
Yes, I believe you're a therapist now, aren't you?
Wonks wrote: Wed Jan 15, 2025 4:50 pm
"Why do you feel that anyone might like a banjo to be louder?"
Post by adrian_k »
:lol:
Some problems just can’t be fixed though…
adrian_k
Post by Kwackman »
Drew Stephenson wrote: Wed Jan 15, 2025 4:58 pm"Why do you feel that anyone might like a banjo to be louder?"
The last 3 words of that sentence aren't needed.... :D
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
adrian_k wrote: Wed Jan 15, 2025 5:24 pm
:lol:
Though at least the padding in the cell helps muffle the sound.
