Hello,
Bit of a shot in the dark.... has anybody got a Forefront FT4 from 90s that can send me instructions for setup?
It's a little midi filter box with 1 button but able to do a load of different filtering by sending it info from a midi keyboard.
I found an archived 1998 site but there's no instructions on there.
I hope to filter out info from all midi channels bar 1 so I can control an annoyingly Omni receiving synth.
Thanks for your help
Forefront Technology FT4 Midi Filter
- John Otters
New here - Posts: 4 Joined: Wed Jan 08, 2025 9:30 pm
Re: Forefront Technology FT4 Midi Filter
John, firstly, welcome to the forum and secondly, sorry, don’t have an answer. Probably like you and others here, I googled, but nothing came up for this FT4 model. It’s a shame, it does sound like a very useful little device.
Didn’t want you to think no one was interested, it’s just not easy to find an answer.
Thanks very much for having a look Bill and getting in touch. I've actually worked out how to get it working by sending it sysex. I'm going to write up some 'instructions' and post on here in case anybody else comes across one.
- John Otters
Well done for figuring it out! Thank you for offering to share your findings. Anything you post here will have value. SOS has very good search engine credentials, so any relevant material posted here will be found and used by others.
Forefront Technology FT4 Midi Filter - INSTRUCTIONS FOR USE
In response to my own post......
Here is some info on this along with some badly written instructions for use. Hopefully this helps out anyone who has one or gets hold of one and has no instructions.
The box only has 1 button and an LED so it's not obvious how to get it to work.
It is powered by the MIDI cable. It needs no battery but remembers it’s programming.
You’re supposed to be able to program from MIDI Keyboard, MIDI Program Change or special software (out of date).
I managed to change it’s settings by accident using midi notes/program changes, played about for ages using trail and error and finally worked out how could send sysex to program. Once I worked out the SysEx route and got it doing what I wanted, I gave up trying to find out more.
Short press button to cycle between:
- Slow Flashing light = Filtering
- Solid Light = Bypass
Hold Down button until fast flashing to program
- Send program SysEx e.g. with Midi Event in Logic
- Fast flash will stop when program received.
You can send SysEx from FT4, keep holding down or long press button from fast flash.
This allows you to see the current state of the FT4.
Editting the SysEx..
Example below Filters Channel 1
00 F0 00 20 11 00 04 00 3C 00 5E 7E 7E 7E 7E 7E 5E 10 7E 7E 7E 7E 7C 7E 7E 7E F7
This example filters Channels 1, 5, 6 & 10
00 F0 00 20 11 00 04 00 1C 00 5E 7E 7E 00 00 7E 5E 10 7E 00 7E 7E 7C 7E 7E 7E F7
Example Filters all but Channel 16
00 F0 00 20 11 00 04 00 1C 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 7E F7
To write sysex to control filtering:
Leave 1st 9 codes as is. 00 F0 00 20 11 00 04 00 1C
Edit the following 8
Leave the '10'
Leave the F7 at the end
I guess 5E / 7C etc. could be changed to filter different aspects out of each channel. I assume 00 lets nothing past. I only needed to pass note info on 1 channel so I've given up investigating, I’ve seen Filter out Clock & MTC Quarter Frame though.
I used ’SysEx Librarian’ to ‘record’ the sysex coming back from the FT4. This also allowed me to check what was being filtered by the FT4 whilst I sent it info on different channels.
Info from the archived website found via Internet Archive:
The FT4 Filter is an ultra-compact unit (74 x 55 x 25mm), providing comprehensive programmable options for the filtering of MIDI data. The unit is powered by the MIDI input, and so does not require batteries or external power supply.
The following data types can be filtered on any MIDI channel, or any combination of channels:
- Note On/Off
- Channel Aftertouch
- Poly Aftertouch
- Program Change
- Pitch Bend
- Controllers
Additionally, any combination of the following "system" messages can be filtered:
- Clock
- Start, Stop & Continue
- Active Sensing
- Time Code
- System Exclusive
The filters can be programmed by three different methods: using a MIDI keyboard, using MIDI Program change messages, or via System Exclusive messages using the free FT4 Editor program for the PC.
Leave the '10'
- Note On/Off
- Poly Aftertouch
- Program Change
- Pitch Bend
- Controllers
- Clock
- Active Sensing
- Time Code
- System Exclusive
- John Otters
Wow - thanks for all that detail John!
It's going to be a godsend to anyone who gets hold of one in future
With helpful posts like that, even after only three posts here you can now claim to be a full member of the SOS Forums, whose members are likely to buy you a drink if they ever bump into you in person
Posts: 22577 Joined: Wed Jan 13, 2010 8:44 am
Ah of course - I should have said excepting SOS Forum members in Yorkshire
Thanks for the welcome and nearly the manual!
- John Otters
