Reconnecting synths after studio tear down
Post by jaypodesta »
Currently looking at a lonely patch panel SEM after taking most of my studio apart so the leaking radiator can get fixed. Unplugging everything and reconnecting everything should be fine. Have labelled every power adapter and popped the cables all in a nice new storage box.
And taken a million picture of what was plugged in where on the mixer.
But suspect the problems will come when I need to get synths and drum machines to work and talk to each other again. Any one got any tips after anything similar?
jaypodesta
Posts: 50 Joined: Tue Dec 14, 2004 12:00 am
Re: reconnecting synths after studio tear down
Post by IAA »
When I did it ( :crazy: ), I labelled all synths (stereo outputs included L & R), all sockets and PSUs (cause they all look the same :headbang: ), drew a wiring schematic to inputs on AI.
All midi and usb cables were marked too, and I put them back one at a time testing as I went.
Just take your time and label everything!
I had one cable where a marker came off but it was obvious where it went at the end!
Good luck
Ian.
IAA
Posts: 1621 Joined: Fri Dec 28, 2007 12:00 am Location: York
Post by BigRedX »
So long as everything was properly labelled you should be fine.
In the 90s I was in a band that took most of our studio to gigs. I'd spend the evening before dismantling everything and packing it up and then a second evening afterwards the reassembling everything ready for the next round of rehearsing, writing and recording. It helped that most of the gear was in 19" rack cases and all the interconnections were made with clearly labelled patch panels and leads.
BigRedX
Well thanks both. Seems like I have done all I can.. Think the thought of pulling it apart [and then putting it back together later] was more stressful than getting on and doing it.
jaypodesta
I'd just add: be methodical when you reconnect stuff and test everything as you go along. That way if you do find you've introduced a problem (like a ground loop or some other source of noise) you'll know exactly what the cause is and be able to troubleshoot it directly.
Posts: 29713 Joined: Sun Jul 05, 2015 12:00 am Location: York
I'll be sure to do that, thanks. Had already decide to stagger the reintroduction of a couple of Elektron boxes [and perhaps a couple of keyboards] so that will probably help.
jaypodesta
Post by R_A »
jaypodesta wrote: Wed Feb 05, 2025 5:11 pm Currently looking at a lonely patch panel SEM after taking most of my studio apart so the leaking radiator can get fixed.
I'm in a similar position. My studio was recently flooded with water and I've been moved into temporary accommodation for a year by my insurer.
The course I've taken is connecting the minimal amount of kit. Then I plan to add instruments & effects processors into the equation if and when I need them. I'm currently only using about 30% of my equipment.
Good luck with hooking it all up!
R_A
Posts: 252 Joined: Thu Jun 26, 2008 12:00 am
Experimental / Ambient
https://www.rudiarapahoe.com
Re: Reconnecting synths after studio tear down
That sounds horrendous. Hope it all ends soon and works out.
jaypodesta
Post by BillB »
Drew Stephenson wrote: Wed Feb 05, 2025 5:51 pm I'd just add: be methodical when you reconnect stuff and test everything as you go along. That way if you do find you've introduced a problem (like a ground loop or some other source of noise) you'll know exactly what the cause is and be able to troubleshoot it directly.
And while you're testing as you go, don't cut corners like I did and connect stuff that is live - I killed a (fortunately not expensive) pedal that way. Keep turned off to connect. turn on, test, turn off.
BillB
Post by Ben Asaro »
Did the rebuild happen yet, [edit] Jay?
Since I don't have a dedicated space for music-making, tearing down and rebuilding is a weekly occurence in Casa Asaro!
Ben Asaro
Posts: 3480 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Post by BillB »
I'm not doing the rebuild, Jay (the OP) is doing it. Although it does feel like my studio is never quite finished..
BillB
Post by Ben Asaro »
BillB wrote: Thu Feb 06, 2025 1:23 pm I'm not doing the rebuild, Jay (the OP) is doing it. Although it does feel like my studio is never quite finished..
Thanks, Bill! :D Corrected!
Ben Asaro
Not yet.
jaypodesta
Post by IAA »
But your output is phenomenal and the quality mind blowing!
Ian
IAA
Post by Ben Asaro »
IAA wrote: Thu Feb 06, 2025 4:50 pm
Ian
Aw, thanks, Ian! Really appreciate it!
Ben Asaro
