Pedal into Hi-Z question.
Post by Dynamic Mike »
I've just purchased & set up the SSL 2+ Mark II which has 2 Neutrik XLR Combo sockets for Mic/Line inputs mounted on the rear. Purely for convenience is it okay to plug the line outs from my Pod Go into the Hi-Z instrument sockets on the front just for monitoring when practicing (not when recording) to save constantly having to unplug/plug the mics? The DI inputs automatically disconect the XLR inputs when they detect a connection.
I thought it best to ask before trying it out in case it might cause any damage.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
Re: Pedal into Hi-Z question.
Yes, you won't do damage. Use your ears to set the gain so that the inputs are not distorting.
I can't find anything on the Line 6 page giving the actual specifications of output levels for the Pod Go, but you should be fine with plugging it into the Hi-Z inputs without causing any damage, just listen for any overloading as the front inputs on the SSL have a max level 9dB lower than the line inputs on the rear.
[EDIT - Sam beat me to it]
Posts: 29713 Joined: Sun Jul 05, 2015 12:00 am Location: York
Thanks guys, I figured it would probably be okay because people use pedals directly before the instrument input into a guitar amp. But now I feel reassured I won't cause any damage by trying it. I'll start with the pod go volume fairly low and see how it sounds.
Dynamic Mike
Since you are doing this purely for convenience when monitoring certainly not a problem but people should be aware that some high Z inputs on AIs (and a few mixers) are deliberately made to have some "attitude".
The makers of them boast of a "musical discrete FET input" which is "distortion" in engineering terms!
Some folks will of course like the 'hair' that such inputs deliver but I prefer to have as transparent a device as I can get. I am quite capable of buggering up the sound post tracking thank you very much!
ef37a wrote: Fri Feb 07, 2025 10:50 am The makers of them boast of a "musical discrete FET input" which is "distortion" in engineering terms!
I think the 4K button switches the 'SSL Attitude' in and out as required. I don't know whether it works on the instrument inputs though as they seem to bypass any other processing. Won't really know until I try it.
Dynamic Mike
