Evening all,
I am looking for a 2 channel device that will take a line level input and record either wav or mp3 format files to a removable USB drive.
I’ve had a look and can’t find anything. Compact flash, SD cards but not USB drives. Does such a beast exist or did I dream it ?
Cheers
Dave
USB recorder?
USB recorder?
- Lizardpoint
Regular - Posts: 209 Joined: Sat Oct 18, 2003 12:00 am Location: Biggin Hill, Kent
Re: USB recorder?
A cheap SD-USB adapter would allow you to record to SD cards and then read/copy them to a computer just as you would a USB stick. USB sticks are not ideal as recording media simply because they stick out of the device and so are vulnerable to physical impact/damage while SD cards and similar are more or less fully enclosed in the machine.
Forum Aficionado - Posts: 22188 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: USB recorder?
The Behringer X32 has exactly this, with your USB stick being used to record. But it's not really a portable device. A bit like shooting a mosquito with a bazooka.
And of course the most (if not all?) Zoom handy recorders can be switched into an USB device easily. That's how I use my H4n pro. Record stuff (onto the built-in SD card), connect via USB to computer, transfer WAV files.
Good luck!
Hens Zimmerman
Good luck!
Hens Zimmerman
Re: USB recorder?
Lizardpoint wrote: ↑Thu Feb 06, 2025 10:00 pm I am looking for a 2 channel device that will take a line level input and record either wav or mp3 format files to a removable USB drive.
Tascam and Denon both make stereo, line-level rack-mount recorders that can record to USB drives (as well as SD cards). Eg:
https://www.tascam.eu/en/ss-r250n#feat
Posts: 42740 Joined: Fri Jul 25, 2003 12:00 am
Re: USB recorder?
This (and not just Zoom of course, Tascam and Olympus devices all work this way) plus using an SD card -> USB adapter are both viable and easy ways of accomplishing what you want.
- ConcertinaChap
Jedi Poster -
Posts: 14682 Joined: Wed Jul 20, 2005 12:00 am
Mr Punch's Studio
If a tune's worth playing it's worth playing lots!
Re: USB recorder?
Apart from Hugh I suspect we have all assumed you are looking for a portable device? If not then Hugh's rackmount suggestions will get the job done. But if you do want something portable then I fear you are out of luck...
Re: USB recorder?
Given how bad the search engines on those platforms are I suspect a month won't even scratch the surface...
Re: USB recorder?
You'd be better off typing USB AUDIO RECORDER, just to reduce the number of photographic storage devices and their ilk.
The reference to line inputs made me think this was more a fixed location than portable application. Hence the suggestion of rackmount hardware.
Re: USB recorder?
Hugh Robjohns wrote: ↑Fri Feb 07, 2025 10:56 pm You'd be better off typing USB AUDIO RECORDER, just to reduce the number of photographic storage devices and their ilk.
Good points Hugh...
